Is it possible to put a softcam on a VU+ solo 2 ??
Latest Vix image
Many thx
they can be added on all images
via the tmp folder then you load
them from the manual package install
section in the box menu, here are the cam
packs for you
http://www.4shared.com/dir/wnyHV50A/VIX_CAMS.html
Last edited by digicon; 1st October, 2013 at 11:28 PM. Reason: Removed Cam Pack and replaced with External link
Please Read Carefully!
Hi Benny,
Sorry my good man but we cant hold any form of cams on the site including built into images due to the rules, We can though link to them externally from other hosting sites without a problem so i have edited your post to reflect this.
Thank you
Hi many thx benny/9 for the reply....
Sorry my 1st post is misleading (sorry about this) i already have some of them installed on the VU....ccam 2.4.1 & mgccam also oscam
the box is running great many thx for the help off other members of the forum...
I mean the k**s like the ones in the Latest Technomate Softcam Keys *Regularly Updated*
or similar to work with the VU
Not sure if this is possible (i could do it on the F3 box i had) but is it possible on this box.....
or am i barking you the wrong tree ???
Only had the box under a week....as digicon assured me that the setup it easy (which it was) & a lot of reading helped thx again for the pointers mate
Had a play with the B/H latest image...it's ok... but now i find the openvix is more user friendly & easier to get your head round...
I have found out how to load stuff on the box via ftp & ipk & usb....editing files that i need to....
After all the the above said.......i have the files for the F3 box that opened some sat's that i could watch. lets say 39.2E ...N**a S***t... is it possible to put the same file's on the VU
attached below...
Or again am i barking up the wrong tree...to get what i want
Just cannot get my head around where to put them ...&..which flies go where .....iv'e try'd them in Var/keys..also Usr/keys
Any pointer's plz anyone thx in advance...
Ok
Here we go not tested by myself but here is the latest Dreambox softcam.key file which goes into /usr/keys:
Update: Bulsat 39.0?E Irdeto Active and Next key's
Cablecom, Swiss Cable
SRTV Feed 16?E BISS
NBA Pool Europe 10?E BISS
Rai october 13.0?E
Rai 13.0?E September
NBA TV HD 10.0?E BISS
Barca tv (feed) 10.0?E BISS
MUTV 10.0?E Biss
USRSC Europe ESPN 10?E BISS
ETV 3.1?E BISS
EVN TV BISS 7?E
Sinema TV Aksiyon HD & Sinema Ask TV HD 4.9?E BISS
NLO TV 4.8?E BISS
Pershy Natsionaly 4.0?W BISS
REN TV 49.0?E BISS
Art Prime Sport 49?E BISS
BBC Package 27.5?W BISS
Fox Crime Africa SD 12.5W BISS
ESPN Caribbean & ESPN Syndication 15?W BISS
Eurofootball Gonki 9.0?E BISS
TNTsat Viaccess 19.2?E
CS SkyLink 23.5?E CryptoWorks
DigiTurk 7?E CryptoWorks
Upc Direct 0.8?W CryptoWorks
ORF & AustriaSat 19.2?E CryptoWorks
UPC Cablecom (Swiss cable network) NagraVision
Thanks to Serjoga for all the hard work, just to let you know you will need 2 cam emulator's for this key file to work one begins with C and the other begins with M and ends 1.38.
Just to let you know why you need the 2 some are read by one emulator and some by the other.
P&D (2nd October, 2013)
Hi digicon many thx for the answer
i will try them later when i finish at work.....
When you say i need the 2 files ...i now have them....do you just swap & activate them from the menu...i know they will not both run at the same time...
what i'm asking is one file will work with some sat's (lets say the M file) .....if the sat does not clear then swap to the other file (C) ??
Sorry to be a pain mate...so the dreambox k**s are ok for the E2 systems....
Regards P&D
Dreambox are Enigma2 so yes they work on any E2 Linux receiver.
And again correct for some channels that wont open on one cam with the keys you swap to the other cam, as you are now using the Vix image i am unfamiliar if it has an Autocam function built in.
Blackhole does have Autocam function built in so when you get channels open with say Cam A you save these to open with A and the rest you save with Cam B. So when you go to that said channel it opens with either A or B automatically.
Like i said i have no idea if the Vix image has this function so you may have to have a look around the menu system
Hi digicon many thx for the pointers
I have re-installed B/H 2.0.6 with both the files you have mentioned above...all working great mate only had time to check 39E & N*** S***** opens
so i will check he others later also thx for the pointers with the autocam....great little thing save swapping it everytime you change the sat ...
My next challenge is find sats i can open......1. last question mate should the sats above that have the Bliss keys open with the same file ???
Regards P&D
They should yes again though it will depend if the key in the file is current or not even though they list them up to date even the softcam makers have been known to leave old and dead keys in the file, try a few and see how you go as some may have a clash with others due to format
P&D (3rd October, 2013)
Many thx for all your help digicon....
You are defo on my Christmas card list
Only for your advice i wouldn't of took the next step into the wounderful world of the Sat's
As you said to me in one of your post's it's not the daunting to setup & take the next setp (glad i listened to you).....
My advice to anyone & all
If your thing of upgrading from the CHEAP boxes go for it....motor dish setup 3 days (Don't laugh) 1st attempted
Box setup 3 days after trying the Vix image & the B/hole image (& many pointers from forum members) Many thx to all.....
I now can pass on what i have learnt this week to other members starting out....
Again many thx Phil
Thought i'd bring this thread back rather than starting a new one. Not sure where to put the key files on my VU+Duo2. Any pointers? cheers.
DigitalVandal (23rd March, 2014)
top man. thanks for almost immediate answer.
And while we are on it might as well try and keep them up to date:
Thanks to Serjoga for the key File
ADD: ESP2 NE Russian 13.0?E 11240 V 27500 CCW's
NTV Mir 4.0?W BISS
Juventus TV Channel ("ITA 392") 5?W BISS
BBC Package 27.5?W BISS DOWN
NLO TV 4.9?E BISS
Chveni Magti, Magti Kino, Comedy Arkhi, Magti Hiti HD 4.9?E BISS
Italy Service & Italy Service 2 & Italy Service 3 & Italiy Service 4 9?E BISS
FOX Sports 9?E BISS
BARCA FeeD 10.0?E BISS
NBA Pool Europe 10?E BISS DOWN
STS International 13.0?E BISS
K**** D1 16.0?E BISS
SRTV Feed 16?E BISS
Topaz 1 21.5E BISS
CaspioNet and CaspioNet_test 31.5?E BISS
BTB 31.5?E BISS
Comedy Central 31.5?E BISS
Region TV 46?E BISS
CTC Love 85.1?E BISS
Mir Belogorje 85.1?E BISS "radio"
TNT Sat (France) HD 19.2E Viaccess Only with o****-ymodv18-t50
TNT Sat (France) SD 19.2E Viaccess Only with o****-ymodv18-t50
Ant-1 Europe 9?E Viaccess
GMM Package 78.5?E Irdeto
DigitalVandal (24th March, 2014)
Do they work with 1.35 as they're not opening for me.
