latest channel list for f3/f5 as requested incl asian
TP_PROG.rar
TP_PROG.rar
stevo57 (11th October, 2013)
Hi im new to all this,
after i download this file what do i do with it?
I don't know much about downloading and extracting files etc,
any help will be appreciated loads
best thing to do is go on U :ube And check out uploading channel list![]()
- Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
- In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
- Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
- Once the upgrade has completed restart your box & voil?!
Guide on page 1 of ajs channel list. Andy
Ps
very important if u do put a new channel list on make sure u delete old one fist .if u don't it will brick ur box ... Useless after that
Before you start you will need a USB stick and need Winzip or Winrar install on your PC
Go to this website
https://www.bradforddealer.com/download/
Once there, go to the section
Channel List TP PROG
Download this and save onto a USB stick
Now plug the stick in the F box
First of all go to the Menu Panel and into the Edit Chanel
Click on Delete All channels ( and delete)
Next go Tools
Click on Upgrade by USB
Where it says Upgrade Mode at top press sideways on the remote till you see Misc file
press start (OK button)
then highlight TP_prog/press ok it should put a green tick at the side
press the yellow button on the remote wait till the box does its thing
Once done press exit button on remote ( it should save settings)
Exit it completely and then reboot the box.(make sure you do this otherwise it will not be saved)
Hopefully all channels will be back.
If this is to hard for you to do, then just ignore all above and go into Installation in menu button and press Single satellite search and press scan***8230;..this will scan the whole satellite and store channels***8230;***8230;.but these wont be in favourites but in ALL***8230;( however this will also download all adult channels as well
never had one brick on me as yes its only duse with dogy chanle list and you can recuver by rs232 program and files
are you changing the image file to misc if you don't your box wont find the file
Thanks for your response:
I am pretty sure I followed the guide above step by step but I will make sure I have another go when I'm home from work. I will let you know how I get on...
Cheers.
Thanks for your help!
Managed to get the tv prog file installed and working.
However, the channels are not in order as per sky uk.
What I am looking for is sky sports being 401, sky one on 106 etc. does such a list exist?
have a look here at Sattv5 channel list see if it's what your after http://www.digital-kaos.co.uk/forums...1/#post1980897
sorry but do you have a channel list for hotbird lastest please?
