Bit of help pls
Results 1 to 9 of 9
Thread: Bit of help pls
    Feb 2012
    Default Bit of help pls
    Dont shout pls
    Had to factory default complete box back to when first purchased
    Is the latest patch 133p
    latest soft cam key dated 16-08-2013
    and the latest ADDON IS 3-ADDON_ 002P
    IF I AM WRONG ON ANY OF THESE PLEASE CORRECT ME
    jim
    digicon's Avatar
    If your talking about the TM5402 HD the the latest patch is 135p which i have attached below and the softcam.key file can be found here: http://www.digital-kaos.co.uk/forums...ml#post2105551
    The ADDON 002p is always the same
  3. The Following User Says Thank You to digicon For This Useful Post:
    Nutsandbolts (4th October, 2013)
    Oct 2011
    Hi. Good patch.. it also opens up TNTSAT channels on 19.2 Well done Mr Phantom.
    Regards.
    Feb 2012
    thanks for your help
    jim
    Is there an equivalent patch for the 5402HD M2 version available please ?
    digicon's Avatar
    Quote Originally Posted by Carew6 View Post
    Yes there is but be warned that this appears to have lip synch issues after a while i have uploaded here for you but personally on the M2 version i would stick with Patch 101p
  8. The Following User Says Thank You to digicon For This Useful Post:
    Carew6 (5th October, 2013)
  9. #7
    Senior Member wongers's Avatar
    liverpool
    do i have to open this file before loading on to a stick or can i load it straight on and then install to my box cheers
  10. #8
    digicon's Avatar
    Yes you will have to extract it and place onto a USB stick and flash from there.
  11. #9
    liverpool
    thanks m8 (the penny will drop one day)
