Results 1 to 2 of 2
    Birmingham
    Default Reading 0f82b with Xprog-m - Is there a trick as it will not read!
    Hi guys,
    I'm trying to read 0f82b 705e6 with xprog.
    Its connected correctly, and even the oscillator from a motorola key across pins 3 and 4 as the manual says but still all I get is "device silent!"
    I connected directly to the key, and on the 28 pin adapter but still no read!
    Is there a trick, or a certain way of doing because I have tried alot!
    PS- I can read it with 705E6 programmer, but trying to help a mate who only has an xprog!
    smayer's Avatar
    Jan 2012
    Lift pin 1 in key mcu and choose frequencie 2 or 4Mhz same as crystal. .11 keys use 4Mhz all others 2Mhz.
  3. The Following 2 Users Say Thank You to smayer For This Useful Post:
    ettaoussi (19th August, 2016), jebo (4th October, 2013)
