Results 1 to 8 of 8
    Top Poster + -Hox-'s Avatar
    Jun 2008
    Bristol, UK
    Default Web access for NAS drive?!
    Evening all,
    I've not long had a Buffalo Terastation, and I want to access it from outside my network... it's not a brand new drive, the newer ones have all the web access crap built into them to make it easy
    Anyway, I'm not too pie hot when it comes to networking, does anyone have any info that might hold the key?! I've been on google all bloody night!
    Cheers!
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    If you want to ftp to it, forward the ip address of your modem to port 21 in your router settings.
    You can get your modems ip address at What Is My IP Address? - IP Address Lookup, Internet Speed Test, IP Info, plus more.
    If you want to access the web interface, forward the ip address to port 80.
    Get Digital Kaos on your Apple or Android device with Tapatalk
    Jun 2008
    Bristol, UK
    Cheers for the reply DF.
    I'm guessing that port forwarding it to the web would open the flood gates and anyone could have access to it? I need something with some level of protection, like a login or something.
    I've seen so many bits of info on the web, it's just plain bloody confusing me!
    May 2009
    I would imagin that your nas drive has some form of security login when you access it so this should suffice as long as you have changed the default login details, Also I would setup port forwarding on a random high port as it is mainly ports 1-10000 that are scaned, the setup would look a little like external 12451 to internal 80, you would than have to brows to it using http://yourip:12451
    Jun 2008
    Bristol, UK
    Cheers for that mate, I'll have a go tomorrow!
    Jun 2008
    Bristol, UK
    Well, after messing about with it all (and failing), I read that I needed DynDNS in my life. Once I had that box ticked, I still couldn't get anything to work. I think I might be fighting a losing battle!
    Thanks for the ideas guys.
    Jan 2020
    Quote Originally Posted by connercole View Post
    You can also use https://www.purevpn.com/what-is-my-ip I recently used it and was amazed how in detailed they have each and every information of the visitor.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Just use filezilla and build your own server. Just port forward in your router
