Results 1 to 5 of 5
    Newbie Berur's Avatar
    Mar 2013
    Default Problem Golf V 2.0 TDI 170 DPF
    We empty the particle filter to a golf V 2.0 tdi 170 DPF volta and I have used and I ecusafe the fault disappears filter image in the box could alludarme thanks instruments.
    Bulgaria
    What you want men? I don't understand.
    Try to reset the adaptations for particle filter in the ECM with the original software.
    if it s PPD 1.2 use volta only and test
    Apr 2012
    Hi,ominimicu, do you think the volta is enough, I have an same problem
