Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Jan 2013
    Default Add new LNB 28 E Help
    Hello.
    I have a dm500 and i use vhannibal settings.
    Now i have 3 lnb 13E 16 E and 19 E
    I want to add 28E
    How can i configure the NEW satellite And add bouqetes without loosing the other sats.
    I am asking because Vhannibal doesnt have a settings that use the 4 sats im interested
    digicon's Avatar
    Jul 2009
    16? east is the oddball out so to speak you would have to download a Multisat list and edit out the ones you dont want
    Jan 2013
    Quote Originally Posted by digicon View Post
    Im managing to make a Hybrid Settings
    Jan 2013
    Hello.
    Can u tell me a strong/weak frequency so i can use it as a "benchmark" on 28.2E ?
    Jan 2013
    I have installed 28.2E lnb. i chose as benchmark 11836 H 27500 and i got 79 % quality on that frequency.
    I tried other frequencies but they are 0% Could that be a problem with my lnb ?
    Jan 2013
    Bump !!
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    that transponder may be used on other satellites aswell, therefore youre pointing at the wrong satellite! best way to do it is get a channel list transferred to your box, go on channel 4 (strongest TP) and move your dish slowly until you get a picture. Then go back to sinle screen and tweak for best signal..
    Have i helped? Hit the Thanks button below!
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
  8. The Following User Says Thank You to .: JaCkPoT :. For This Useful Post:
    Avf130 (7th October, 2013)
  9. #8
    Jan 2013
    Quote Originally Posted by .: JaCkPoT :. View Post
    I tried to load 28.2E vhannibal settings and i couldnt open any channel.
  10. #9
    Jan 2013
    After hours of attempts i finally got signal.
    Now im trying to figure out how to mount the lnb
  11. #10
    Aug 2008
    var/tuxbox/plugins
    Have any success? LNB mounting should be simple, take a read of my guide here..the bit about LNB skewing may help
    http://www.digital-kaos.co.uk/forums...te-dish-11239/
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
  12. #11
    Jan 2013
    I got signal on the dish where i have 16E and 19.2.
    On the dish that i have 13E i havent got signal
  13. #12
    Jan 2013
    Bump !
    Any idea
  14. #13
    digicon's Avatar
    Jul 2009
    Do you have 2 separate Dishes as in one with 16? & 19.2? east and another one with 13? & 28.2? east or are they all on the same dish
  15. #14
    Jan 2013
    I have 2 dishes 80 cm each
    One has 16 and 19.2
    One has only 13.
    I want to install 28.2 on the dish that has 13e
  16. #15
    digicon's Avatar
    Jul 2009
    Then 13? east should be prime focus and 28.2? east should be the offset due to it being the more powerful satellite slot
