Results 1 to 10 of 10
    motorsportsz's Avatar
    Jun 2012
    Default Anyone can write a file for a k03s hybrid on a mk4 golf gti?
    Hi there
    I have a 2003 AUM mk4 gti with the following modifications:
    Stainless exhaust system
    Audi tt injectors
    4bar fuel pressure regulator
    3" MAF
    K03S HYBRID TURBO
    The hybrid turbo has rs6 internals in it
    Rs6 Compressor Wheel, Machined & Ported Compressor Cover, Uprated 360 Degree Thrust Bearing, Rs6 Turbine Wheel, Machined & Ported Turbine Housing, Standard Actuator.
    Has anyone made an successful remap on one of these? Also what safe power gains will the car make?
    PRESS THANKS + REP IF MY POST HAS HELPED YOU
    DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
    Bulgaria
    You have to make tuning on the dyno! Impossible to calculating only using theory!!! Don't make experiments with your car. Find best tunner and the car on the dyno!
  3. The Following User Says Thank You to oem For This Useful Post:
    m3evo (1st November, 2013)
    Jun 2012
    Dyno is the only way?
    upload your ori file........please
    dyno is the only way .We cant figure out how your hybrid and mods work without Dyno figure and loggs .
    carmageddon's Avatar
    Italy
    this configuration will create problems...is not necessary 4 bar pressure regulator fuel but only calculate appropriate injectors (for power you need) and right estimate for new injection time, lambda, torque etc etc etc.
    dyno is not necessary for regulation, you need dyno only to check your final work how much power develops
    Jun 2012
    Quote Originally Posted by carmageddon View Post
    This is what I thought
    Dyno is no real advantage. It can be done but needs a few passes with datalogs.
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
  10. #9
    Dec 2010
    Tuning without actually measuring datalogging AFR . What a joke. Tuning with out a dyno is like stabbing an intruder in the dark
    You will fail
    sure you log on the road but road will not tell you the optimal mixture and spark adavance . Dyno will
    Most of this forum is not about real tuning. It's about making a quick buck by guessing what the car needs and not actually giving it what it needs
    The funniest thing I see on this forum is people looking at a tuned fuel map and saying whether it's good or not . You cannot see what the motor wants
    People that own dynos , dataloggers and who are passionate about there work know this. The people making a quick buck tuned file ignore this fact so they can continue making money
    Even two motors that are the same will not require the same injector time. There are too many differences in manufacturing , cam timing , cylinder sealing and injector flow rates.
    Tuning all superbikes all day everyday
    fileservice
    Ninja 250, 300
    Zx10 all till 2013
    Zx14 all till 2013
    Panigale , new mts and hypetstrada
    Hard to solve map projects , ski-doo done
    NEW CBR1000 600 AND VT CRUISER MAPPACKS AND REMAPPING
  11. #10
    Sick world
    best files for tfsi and 1.8T vag = Revlimit Forum
