Results 1 to 8 of 8
    Senior Member tony2803's Avatar
    Jun 2008
    Default skybox m3 red light
    i have a skybox m3 all it shows is a red light on front panel (wont boot at all).
    I have tried different versions of upgrade tool and many editions of firmware but I keep getting stb memory error,firewall is turned off on pc (xp) and I have run the config files with all versions of upgrade tools and different timings before applying power to skybox.
    has anyone recovered an m3 box and if so can someone let me know what upgrade tool and firmware to use in recovering my m3..ps power supply is putting out the correct 12 volt supply.
    thanks in advance if some one on d/k can help me..(its doing my head in) thanks.
    Jun 2008
    Quote Originally Posted by tony2803 View Post
    with the responce to my thread,you would think I had posted this problem in black ink.
    digicon's Avatar
    Jul 2009
    Lack of response could also be attributed to the local Open/Skybox brigade reading your initial post and thinking that you have already tried every known avenue out there to recover it. And so any more input would just lead you going round in circles again.
    Jun 2008
    Quote Originally Posted by digicon View Post
    would appreciate it if someone has an m3 firmware dump from their working m3 and can post or pm me,its the only thing that I have not yet tried..thanks.
    May 2013
    The Skybox F5/F3/M3 are all the same firmware, im sure of it.
    Have you ever had to recover your box before, using the PC/Laptop your trying to use know ?
    Are you using a proper PC with a com port or a USB to COM cable ?
    Jun 2008
    Quote Originally Posted by sattv5 View Post
    no not this particular box,and yes using desktop pc with correct com port and null modem cable.also run config file and turned off xp firewall and ticked load bootloader.
    May 2012
    Everything you need is in the 8M folder.
    Make sure you use the SKYBOX_3601HD_CMT_130327079B.abs
    Oct 2008
