hi can anyone help me getting a channel list for the vivabox looked everywhere but cant seem to find one anywhere thanx
been in this game over 15 years and never, never heard of it and never seen it on any sat forum either
so I doubt you will get any info on it
I could only find information from here:
To source a channel list or even the format it is in we would need to know what original box this is as in Cloned or a re-badged version
I have the files but not sure how to post them up on here????
Note:All information given is to be used for educational purposes only and should not be taken seriously.
agustinazo (8th May, 2018)
Here you go this is the firmware and the channel list hope it helps
agustinazo (2nd May, 2018), super jumbe (3rd April, 2014), Vivavoz (9th May, 2018)
Any body having problems with signal quality on this box
channel list you all been waiting for.
Hello, I already installed it. It is old one.
I need some channel list for 28.2E astra 2E.
My satellite antenna already aligned some frequence of 28.2E.
But I can't see BBC channel. Could you give me your advice?
I'm in south France. the antenna for satellite is 110cm. and Viva HD7000.
I can't see any UK channel.
Best Regards
How we suppose to know you are bassed in France, other day a person needed help in Africa, at list tell us your locasion if you all need help!!!!
Quite by coincidence, I am trying to set up a Vivabox 7000HD in France as well. I got a pretty good channel list for Astra 2E, including BBC and the box worked well before the 2E signal went bad on me due to poor weather (I need a bigger dish!).
There are a few teething problems though. Its all very well having firmware upgrades via a PC or USB, but that's not much good if you can't find a supprt website. The box and instructions don't mention any manufacturer. Any ideas?
More importantly, I specifically bought this on ebay UK as the cheapest satellite FTA freeview box I could find with built in wi-fi. That's what every ebay and retailed webiste says is a key feature. Now that the Astra 2E satellite signal has gone down, I tried to set up wifi. However, the setup routine says there is no wi-fi device detected. Have I missed something?
Basically, any info at all about this box would be helpful - thanks.
I am having a big problem, I just bought a new one, and the install Antenna option is disabled.
How can I start searching for FTA channels?
Will this Firmware upgrade solve the issue? Is it the latest one?
Any help please?
Thank you...
