Results 1 to 15 of 16
    dave11674's Avatar
    Florida, UK
    Default vw crafter 2007 dash gone to KM !!!
    hi guys
    did a vw crafter earlier today
    put the dash to 1234 with abritus and blocks sync
    then did ezs with 9s12 progger, which i put my desired mileage in
    went back into the abritus software and told dash to sync with ezs
    it did this just fine
    but now the dash has switched to KM
    its showing the right value in km 173932
    but i need it to display miles and show in miles 108100
    any1 got any ideas as to how n why its changed over to km ?
    its also now swapped the dials round to the mph is now going up as the revs and vice versa
    i tried vcds and went to LT3 option and into dash
    but no coding is open !!
    was told i could change coding from germany to england to get it right
    any help here greatly appreciated
    ive put my dash dump up here as it is now showing KM
    if some1 can show how to get back to km then pls help
    or if they can edit the dump and repost pls
    dash is 25LC640 read with my upa
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    Moderator
    PremierD's Avatar
    Jun 2009
    And your original dash and ezs dump is where mate ?
    dave11674's Avatar
    Florida, UK
    sorry
    didnt save as OBD usually works as i did this vehicle before mate same way no problems
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    yugo45's Avatar
    Probably when did sync back eeprom got recoded.Try to recode dash with AVDI diagnostic.
    dave11674's Avatar
    Florida, UK
    Quote Originally Posted by yugo45 View Post
    avdi can recode if i go into the dash ??
    do u know what cding string i put in ?
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    vcds are genuine one,or clone?
    br.
    yugo45's Avatar
    Quote Originally Posted by dave11674 View Post
    dave
    00xx?0x
    Where is question mark need to put 4(UK).
    This is most commmon coding, I never done Crafter , but it should have this option.
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    I got the same problem after mileage change, so Monday I will try change coding with fvdi and let you know it works or no.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
    Nov 2013
    UK
    What tools did you use?
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    Aug 2010
    Herts, UK
    FVDI MB and R270
    Nov 2013
    UK
    LOL your FVDI is the old software with this bug...
    This bug is fixed for us original AVDI users, and they also fixed anyone who had this problem EEPROM... it pays to have original tools
    HAHAHAHA
    Jul 2011
    report the result ..
  13. #13
    dave11674's Avatar
    Florida, UK
    i got all the coding sequences from abritus
    there is a lot
    but it worked
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
  14. #14
    Aug 2010
    Herts, UK
    Coding do not impossible change with FVDI (don't have this function) and with STAR C4 as well fault: A1 (Instrument cluster) - Faulty variant codding / Control units A1 (Instrument cluster) and (or) N30/4 (ESP control unit) are parameterized differently .
    Good I save original eeprom file .
  15. #15
    captain crackers's Avatar
    england
    Think I will stick to Rosfar and UPA but that's me, anything for an easy life. Arthur.
