No inputs here? ????
Sent from my SCH-R530M using Tapatalk
I have this old DME out of a 1997 BMW 740.
DME BOSCH 0 261 203 474 (0261203474)
BMW# 1 429 578
What is the easiest way to replace original damaged DME for a second hand unit?
Swapping CC460 is enough to have the vehicle running again? Is DME / EWS pairing needed?
Should I do it with GT1/SSS - INPA - BMW SCANNER (vehicle isn't here....so How to wire the rig?)
Does Galleto 2 2012 can work on this DME?
Which programmer works with this CC460?
Any help please!
need to swap CC460.
or read isn from new one ecu and put to ews.
i think the batronix bx48 batego II programmer and an plcc68 socket read this chip.
galletto read only part of flash for tuning.
You need inpa diagnostics.
Read dme page1, page2 and page3.
Post here the screen shot.
Thanks guys. ... I'll look for a programmer that read cc460. In the mean time I will play with inpa to try that solution. ... I'll post later. .
Etas made a programmer for these chips years ago.
ETAS - Innovative L?sungen, Engineering-Dienstleistungen, Consulting und Support f?r die Entwicklung von Embedded Systemen.
It was not sold to the public.
Other programmer is the parallel port device that had been sold by EVC. Out of production also.
greetings,
filecloud
I would like to know what was the end result of this ? I have a water damaged dme and a spare dme. Do I simply swap the cc460 ?
Yes need desolder and resolder cc460, this contains vin, isn... some tools can read cc460 but non fullread... batego bx-48 can read full with socket... but also need desoldering.
Chuckk (26th October, 2019)
Thanks again, I will update as soon as job is finished.
Did you ever get this chip read?
Resurrecting old thread for information updating purposes.
IT IS NOT POSSIBLE TO JUST SWAP THE CC460 CHIP FOR DME CLONING. THE REPLACEMENT DME WILL JUST NOT ACCEPT THE CC460 CHIP. THEY ARE NOT INTERCHANGEABLE.
Something else must be at play here. Maybe some security information programmed into the Intel chip. I'm still working on trying to find out more. I've been trying for a while now to get a full read from a cc460 chip out of circuit to no avail.
The C Clamp is there to temporarily test cc460 in original dme to verify it works in original dme and not in test socket on test dme.
It is possible, Ive tested myself .
If you need I also can share fullread of cc460 m5.2 m44 or m62.
Beware of to much heat and delete this clap... its painfull
Please share a full read for the m62b44. Also how did you do it? What I found is that the cc460 does not read in another DME than the original. Maybe different versions on the m62 engine. Catalyst preparation etc.
Ive iam at PC I can upload, if I remember myself for this threader.
But its unimporant, if M5.2 from m44 oder m62... both same cc460 and same logic to read, write.
Its custom tool.
jl01152 (16th May, 2022)
If you would please upload it I would greatly appreciate it. I couldn't thank you enough.
