Having issues with my DM500, had all the channels before but then some went off due to the frequency, my brother then decided to be clever and messed the box up with factory reset, i now can't get nay channels. Can anyone please help
Can get you fta but you have lost th important file unless you backed it up, Andy.
On this site we are restricted from talking about certain things. If you have lost your premium channels we cant help you but we can help you get your box up and running but the latter our hands are tied, Andy.
I have the box uo and running and scanned for services and transponders with over 700+ services found and 125+ transponders scanned, i have the basic channels, how can i get my premium services running though, i tried to flash again but to no effect...any help other than the file...
Like I said you have erased that part. If you backed it up you can add again but if not its gone forever I'm afraid, Andy.
Check your inbox that's the best I can do to help you,like I said on this forum we have certain rules, Andy. http://www.digital-kaos.co.uk/forums....uk/forums/f5/
With the guide I just sent you can access that file on the other box and press view when you see it but unless your allowed to share the same certain file your screwed, check your inbox again or I will be in bother Andy.
http://www.digital-kaos.co.uk/forums...75/#post810782 look at that you can send forward and back your other channel list, Andy.
hay that is not fair .. I need the latest FTA list for Eutelsat 7 / nielsat channels ... anyone please :d
Hi, have you got the bouquets working fine as I noticed when transfering bouquets over to Technomates that they use different file types (.EPL) I think, so sometimes getting them from a Technomate and using them on a DM (or the otherway round) won't work correctly. I have created a E1 bouquet that was created on a DM 500 that is bang up-to-date. One thing I did found that worked was to open up a DM bouquet in Dreambox Edit (just get one of the forum it doesn't matter if its not one that you want to use) then import the Technomate bouquet and delete the orginal bouquet inserted and that works as it changes the file format. Also for the bouquet (Eutelsat 7 / Nielsat) try Vhannibal's bouquets or Catseye's as they create multiple sat bouquets but I wouldn't be able to tell you if they included the satellites that you require.
