Results 1 to 7 of 7
    Sep 2012
    Default 4'7 bouquets gone help ;;;;commando image
    hi ther ive got dm500s with 4.7 commando image on all workin fine unto yesterday ;;lost all bouquets except one ie says others on top all channels in there but no matter wot i do to get the auto bouquets back no joy also the epg isnt working right tried tuxbox command get auto bouquets no joy can you send us idiots guide thanks ps been great image i just need guidence ps lan cable etc connected properly
    Old Git PaphosAL's Avatar
    Mar 2008
    Try this
    You MUST reboot after overwriting old file with new attached in /var/etc folder, and then run AutoBouquets 5 mins after the restart (in case you have GetEPG set to load at boot)
    OR, be quick on the remote and press BLUE > 2 directly after the restart, which will run AutoBouquets and block GetEPG loading at that stage.
    Cheers- AL
    Feb 2013
    thanks m8 this soved my bt n other channels that were missing issues was not sure wat i was doinf but got it working. i jus copied this file n replaced the other satilite file rebooot then ran scan. box rebooted n all channels were back. thanks
  4. The Following User Says Thank You to barryboom For This Useful Post:
    PaphosAL (20th October, 2013)
    Mar 2008
    In future online updates of C14.7 (kicking off later 2morro, hopefully), any changes we detect in the 28.2E / 19E / 13E streams will be edited and maintained on our ukcvs host, for download and install via a new Commando Toolbox > Utilities Menu item to update your C14.7 satellites.xml file
    We could have been control-freaks and automatically rebooted your box at the end of this 20 second process to activate the changes...
    But instead, we decided on a more gentle approach. NAGWARE messages afterwards, telling YOU to reboot before YOU run AutoBouquets, LOL!
    Cheers- AL
  6. The Following User Says Thank You to PaphosAL For This Useful Post:
    seangraves (24th October, 2013)
  7. #5
    Jul 2012
    Quote Originally Posted by PaphosAL View Post
    Cheers- AL
    Hi did as per instructions but entertainment folder is missing can you please assist
    Thank You
  8. #6
    super jumbe's Avatar
    Dec 2008
    Livingstone
    I would not bother with c14.7 commando, try new PLi image updated on line with all the latest channels list + all cam installed.
  9. #7
    Jul 2014
    got same problem load image all cats there update bouquets they vanish and leave all channel alphabetical order can stop update but it fixes boxnation channel strange tried jade3 image box does not start using commando 5 image any help would be great
