Results 1 to 4 of 4
Thread: ET9500
    Nov 2008
    Default ET9500
    Hi There
    Can you use this box like a skybox F3. If so how do you enter ....................................
    Last edited by digicon; 19th October, 2013 at 05:18 PM. Reason: Read the Rules Please Regarding this subject
    digicon's Avatar
    I am sorry but what you are asking cannot be discussed in great detail on this forum, What i will say is if you have the ET9500 then comparing that to an F3 would be smilar to comparing a reliant robin (F3) to a Rolls Royce (ET9500)
    It will do everything you need and a 1000 times more when you read through a few of the guides in the Enigma2 section/Dreambox Section
    Nov 2008
    Thanks, sorry one more thing. Is the set up exactly the same then with the dreambox ?
    digicon's Avatar
    Quote Originally Posted by tango01 View Post
    The only difference is on the Xtrend you will load images Via USB similar to the F3 everything else is done via Telnet and FTP exactly the same as a dreambox so all the guides apply apart from how to flash the firmware
