Results 1 to 3 of 3
    Top Poster jpr's Avatar
    Jun 2009
    Default Dm 800 start up channel and and audio
    When i set up a start up channel on my dm 800 by going to that channel and restarting the box, Then when i plug it out at night and start the box back up in the morning its not on that channel.Also sometimes cross epg does'nt show when started up in the morning, but i have automatic cross epg download set up for 0.900 in the morning, so not so worried about that.
    Also, when i select the yellow button to correct the audio on the mtv's on 28.2 e which works, but again when i plug the box out at night and plug back in the next morning the audio is not saved.
    Its strange as once or twice when i plugged the box back in the next morning everything was ok.
    Am i missing something is there a way to power down the box at night, I just press the red standby button on the remote and plug out.
    I have the ac3 default set to yes, which stops nar audio from playing and it saves if box is plugged out.
    I'm using nemesis 2.6 image.
    digicon's Avatar
    Why not just use Deep Standby which is in effect similar to unplugging from the wall
    Jun 2009
    I done a deep standby last week, lcd went blank, which must be normal, but then when i pressed the standby button to turn the box back on notting was happening, so i had to plug out the box.
