Results 1 to 2 of 2
Thread: CROSS EPG
    Aug 2008
    Default CROSS EPG
    Hi can any one help please lost some of my tv listings --got the epg channel list just not what programme is on at that moment this has happen before and i have gone to plugins scroll down to crossepg and rerun programme and the epg came back --done the same thing today clicked on crossepg went to download page saying starting download then starting import and stuck there did nothing else went to cofigure checked all was set ok and after all checked clicked on download and the same thing happen stopped on downloading import i dont know if this makes a lot of difference but in configure there was no preferred lamdb listed any help please thanks mial
    Dec 2008
    Hi mate
    Have you enough memory to download the entire epg listings? Try setting up a usb stick and get crossepg to download to there. I once had a similar problem with a older image and was downloading to internal hdd. Solution was to re-formatt the hdd, then re-mount. Dont know why but it worked for me. Probably the first option of usb stick is favourable as you can also store your picons on there as well. This will mean the hdd will not have to boot up on channel selection. Hope this helps.
  3. The Following User Says Thank You to stonewall For This Useful Post:
    mial (22nd October, 2013)
