Results 1 to 7 of 7
    Oct 2013
    Default 77960-TM8-A011-M2 - need help to clear/fix dump file
    HI
    Above unit was reset/clear 3 months ago ( after car accident ) and my car was working fine till few days ago when SRS light shows up. I found cold solder on RA86 ( 93C86 ) eeprom ( somebody charge me $ 55.00 to reset this unit but re-solder job wasn't done very well obviously ). Anyway - I did re-solder eeprom RA86 and now I have 53-3 code on scanner ( before scanner wasn't able to read anything from SRS unit ).
    I hope that this is only data corrupted problem in this memory and somebody will help me to fix/repair this data.
    I was trying to compare my file to "clear" file from this forum but there is so many differences between them.
    this is dump file from my unit - 77960-TM8-A011-M2 ( C0EX0S2902E ) DENSO 150300-1652.
    93c86_2010_insight_DTC_53-3_cold_solder.rar93c86_2010_insight_DTC_53-3_cold_solder.rar
    thanks for help
    Mario
    prusony's Avatar
    Belarus
    Try.........
    PM.....
    Non ut edam vivo, sed ut vivam edo.
    Oct 2013
    Still the same ..
    I did program my RA86 ( 93C86 ) chip twice ( using "your/clean" bin file ) - 1st I did set-up my buffer as 8 bit, 2nd I did set up my buffer as 16 bit
    SRS light still on dash board - do you have original ( before crash ) dump file from the same unit ?.
    Mario
    prusony's Avatar
    Belarus
    What DTC shows scanner?
    (I do not have dumps)
    Oct 2013
    still the same code 53-3
    53-3 is internal module failure, try any file from the forum even crashed file, yes you will get codes for opds but that can be programmed, the key is to try another file and see if 53-3 is still there, if it is then its not the file but actually something bad in the module
    prusony's Avatar
    Belarus
    May be in module is written DUMP from another auto...., and you need to do calibration OPDS,
    Or need dump new dealer unit for auto-adaptation
    I do not have such a dump
