Results 1 to 15 of 15
    Top Poster + pjtaff's Avatar
    May 2009
    Default how do i know if a starview is cloned
    hi please help want to buy a starview 4 usb but dont know what sites can be trusted not to sell me a clone box.
    also i have seen on here about the setup of the boxes is it really that easy to do never done it b4 but doesnt look to bad also how do i dowload the firmware
    all your help would be really good
    sorry also how much are they getting alot of different prices but dont know if its original boxes or clones
    help
    many thanks
    Dec 2008
    Wink
    Quote Originally Posted by pjtaff View Post
    help
    many thanks
    hi there,
    i'm not sure either how you can tell the diference from a clone to an original, i have a starview 4 n got it from ebay so it will be interesting how to tell the difference !
    its really easy to setup just do a factory reset (might already be setup tho so check first)!!! install firmware by going to the download section depending on your area ireland etc.... mine was v1.07 is the latest for me then dl to a usb stick from computer.
    make sure your box is off first then stick it in the box and turn it on.
    install the firmware by going through the hdd button n install,
    then do a scan for channels that's about it.
    when you in the menu press 1570 which is the secret menu and make sure your key is on, hope i havn't missed anything i'm sure a veteran will help u out if i have
    good luck!
    gazza2008
    Guest
    i suggest u look round for dealers look at feedback etc.. we are not aloud 2 tell you who 2 get them off and that..
    yet they are easy 2 setup if you read the guides in here
    also i havent heard that there is a clone box for the SV 4 as they are new boxes... so u will be ok
    hope this helps
    May 2009
    Quote Originally Posted by gazza2008 View Post
    hope this helps
    many thanks for your help will have to do a few search s only other thing what is the chance of getting caught using one does vi***n do a talk back on the cable or is there no way of them knowing
    May 2009
    also can someone give me a link to the firmware that i will need to run the starview 4
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    try this http://www.digital-kaos.co.uk/forums...12-08-a-19539/
    the firmware is in the red sticky threads at the top of the starview section mate..
    gazza2008
    Guest
    no m8 they dont talk back
    May 2009
    hi i downloaded the firmware but i cant open it what do i need to open a .bin file
    sorry to sound really dumb but a bit new to this
    DK Veteran jckw's Avatar
    Sep 2008
    hiya m8 you dont open it its like an image file that you flash thwe box with have a good read here
    http://www.digital-kaos.co.uk/forums/f83/
    we are all learning each day
    May 2009
    i have read through the info on how to flash the box but it tells me to download the firmware which i have done then it says about putting the fimware and the logo files on the usb i only have one thing from the download which reads
    theboxsuperusb-v1.07 wich i take it this is the firmware that i put on the usb but what are the logo files
    sorry i know im prob just a bit thick but i keep reading it over and over again and cant get my head around it i thought when i downloaded the firmware it would just be a couple of files not one .bin file
  11. #11
    May 2009
    Quote Originally Posted by JoK View Post
    many thanks for all your help really glad there are people like you lot out there to help knobs like me, so know all i have to do is put the two files on the usb then,the logo and the firmware then bobs your uncle
    is that all i need for the usb then, if so i just follow the other steps in the guide and i should be good
    many thanks taff
  12. #12
    Feb 2009
    Don't think you need the logo file with V1.07, it's already included, everything you need is in the one file. Just follow the instructions to the word and you'll be fine.
  13. #13
    May 2009
    one other thing i have a older starview box now with this one you have to update the code every so often do you have to do the same with the sv4
  14. #14
    May 2009
    thanks for your help can i use any size usb memory stick or is there a maximum also can you set a timer on the sv4 to record to the memory stick or is it just instant record,
    i have a micro sd with a usb adapter will this do
    sorry to sound a bit thick but its all new to me
  15. #15
    Top Poster tigger001's Avatar
    Feb 2009
    Midlands
    no code updates are needed ,it will do it automaticly
