Results 1 to 14 of 14
    Jan 2013
    Default Lancer evo X 1.5l 2009 flash
    I need of working flash for Mitsubishi Lancer 1.5L 2009 , ECU 1860B170 .
    The car is damaged after testing with some bad diagnostic device.
    Jan 2013
    Urgent please !!!
    Jan 2013
    Or repair check sum?
    Babos's Avatar
    Mar 2012
    in your dump i see CK and maps i think dump can be good
  5. The Following User Says Thank You to Babos For This Useful Post:
    codebg (29th October, 2013)
    Jan 2013
    Thank you Babos for support,
    The ecu is damaged after connect with bad diagnostic equipment, the fan is run permanently, and other modules not have CAN communication with engine ECU.
    Where is the problem?
    Babos's Avatar
    Mar 2012
    try update ecu via dealer tool.
    Jan 2013
    That is good idea but not possible, I looking for good working flash, if anybody have please send me.
    wiseman's Avatar
    What tool damaged your Ecu ?
  10. #9
    Bulgaria
    flash seem to be ok . Have you check with tester for DTC ?
  11. #10
    Bulgaria
  12. The Following User Says Thank You to emiliogsm For This Useful Post:
  13. #11
    Jan 2013
    I don't know with what tool, yes I check for DTC with Abritus , with Launch but not have DTC.
    Not have and live data parameters, only fan is run permanently and other modules not have CAN communication with engine ECU.
  14. #12
    Russia, Kirov
    Your ECU in a boot mode, read 93A66 i will correct it
    Or buy MMCFLASH and unlock it one bution.
  15. The Following User Says Thank You to Bruce Willis For This Useful Post:
  16. #13
    Jan 2013
    Hi Bruce, here is 93S66 , and thank you for support.
  17. #14
    Jan 2013
    I still need help.
