Results 1 to 15 of 19
Thread: Starview 4
    May 2009
    Default Starview 4
    Hi guys
    Can someone help pls just got starview 4 box downloaded the super box firmware connected it onto my digital tv scanned the channels automatically. I only get the local channels all the the freeview channels has disappeared. I'm i doing something wrong can someone help pls.
    stockport
    Quote Originally Posted by lolanre View Post
    Hi guys
    have you done menu, 1570, keycode on?then press default,then back to 511..ynwa
    May 2009
    Exclamation
    Hi, I am having the same problem. I have tried to factory set .... install but could go any further. When I go to menu I get the usual ... intallation to Usb. I enter 1570 but nothing happens.-- Where is the secret menu??? Can some one help please.
    smoggy's Avatar
    Apr 2009
    UK North East
    if you only have the free to air software on the box the secret menu is not available, have you loaded the latest firmware
    May 2009
    Crosby Liverpool
    Default latest Firmware
    Does anybody know what the latest is 1.08?
    mine fell over the other day and can't get it back up
    cheers
    May 2009
    Crosby Liverpool
    Many thanks followed your comments and it worked how does it turn off ???
    May 2009
    Crosby Liverpool
    Default starview 4 in Spain
    Hi All,
    has anybody taken one of these boxes to Spain, its on a po1aris Wor1d site near Murcia,
    did it work,
    Can it work
    the robbers want 400 euros for their box
    any help would be ace
    Manythanks
    stockport
    dont think so.btw,what do you mean by how does it turn off?
    latest f/are is 1.07, has been for months. when things go awol, try menu,1570, hit default(make sure keycode is on), then back to slyspts... ynwa
    May 2009
    Quote Originally Posted by Grayers View Post
    Hi All,
    did it work,
    Can it work
    Manythanks
    Grayers,
    I'm out there on June 2nd, back on June 9th ! Will let you know how I got on. I bought one recently and am about to take it over.
    Having played about with the box at home (I'm not in a cable area) I don't think the auto-scan will help as it's looking at the specific frequency ranges and other settings used in UK and Eire. I need to collar a resident, play with their box, note all the frequencies of the English channels then input them all manually in my box. If the channels are FTA then it should work. If they are scrambled then we are stuffed. The firmware update mentioned on this forum seems only to apply to UK and Eire. Unless someone tells us otherwise, I don't think it will help.
    May 2009
    i have just purchased a starview 4 superbox and have not received the instruction manual could anybody send me one please.
    DK Veteran bigfella's Avatar
    mick's arse in america
    Quote Originally Posted by kirsty View Post
    kristy if u want the instruction manual ..get on to ur supplier they shud send u out ..if u want instructions how to flash ur box with the lastest firmware so u can view the dollar channels ie all the channels available......well u can get a tutorial in the downloads section on this site in the starview part ...u ll need winrar to un zip the tutorial ( if u havent got winrar) u can also find in the downloads part under the p c part ..........if u read thro the threads all the answers r there ...if u get stuck ,,ask theres plenty of good peeps to help
    Jan 2009
    Hi i have had the starview 4 for a while now and suddenly my sky 1 has stopped working? any ideas on what could have went wrong.
  13. #13
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    depends did yo rescan some times they change transponders
  14. #14
    Quote Originally Posted by majid View Post
    try a factory reset and remeember to turn the keycode n default back on
  15. #15
    May 2009
    Default hiya having the same problem. my s/w version is as follow :s:
    Quote Originally Posted by JoK View Post
    Press Menu button
    Goto System Setup
    Sytem Information
    And look at s/w version
    Post back what it says here.
    JoK
    having the same problem my s/w version is as follows:
    model id- c500
    s/w version- 1.06
    boot version- b-11
    date- dec 10 2008.
    i am a first time buyer of one of these boxes and have no clue what to do next please help.
