Results 16 to 30 of 31
  1. #16
    V.I.P. Member Curious123's Avatar
    Apr 2008
    There is a version Barr Allen 4.6.1 but I couldn't get that to load on my box today.
    ftp the plugin to the tmp directory on your dm600.
    Telnet to your box and than go to tmp directory.
    type in
    ipkg update
    ipkg install *.ipk
    This will hopefully install the plugin to your box. After this you need to ftp an *.nfi image file to your hdd.
  2. #17
    May 2008
    There appears to be 2 variants of the Barry Allen Plugin mipsel or powerpc and both state for use with the 600! This confuses me a little.
    It is my understanding that the powerpc version would be for the 600 with an enigma 1 image in flash but I'm not 100% sure.
    This would then make me think that the mipsel version could be if an enigma 2 image was in flash, given the other boxes stated.
    These are assumptions and would welcome some clarification.
    I've only seen a mipsel version of 4.6.1 and didn't think it would work as I have an enigma 1 image in flash.
    @Curious did you try a mipsel or powerpc version? Thanx
  3. #18
    Apr 2008
    I loaded the powerpc version on my dm600 and that worked fine.
  4. #19
    May 2008
    I asked at Cli and @fergy stated
    600 ppc
    7025, 800 & 8000 mips
    So nothing to do with enigma 1 & 2!
    @Curious did you get 4.6.1 to work on your 600. Thanx
  5. #20
    Apr 2008
    I tried the mips version but it failed with some sort of flag error so I just loaded the ppc version.
  6. #21
    May 2008
    Quote Originally Posted by Curious123 View Post
    I'd say that confirms the 600 is def ppc, was that the 4.6.1 ppc version as you stated you had a prob with this in a previous post.
    Thanx again for the feedback.
  7. #22
    Apr 2008
    Quote Originally Posted by Hejira View Post
    600 ppc
    Hi thats correct only ppc will work on 600 enigma1 image in flash will do i have tried this pcd done a guide barry allen in 5 minutes i think someone has posted it here
  8. #23
    Junior Member sherlock's Avatar
    Jun 2008
    Can confirm that barry allen enigma 2 works on dm 600, as i did this months ago, running gemini, edge nem, pli and cli the benifit is that if you change to sat tuner you can use a diff image, also when new image comes out you can take time to set up.
    The main problem is that you have to boot from hard drive images only, or the hd will stop and of course you have a running drive always.
    You can purchase a flash drive with ide conversion then no hd noise. But these are limited to size.
    It is not as hard to install BA as looks but loading the images is a little more difficult.
    Personaly i like it.
    version to use is 4.5 5 powerpc.ipk
  9. #24
    Oct 2008
    Im confused - cant seem to download the link
  10. #25
    V.I.P. Member thered's Avatar
    Aug 2008
    cant seem to get this running
    i installed image into flash
    ftp'd barry allen into temp followed telnet instruction by curious no joy
    i already have barry allen running and gemini and LT on cf card but i cant boot these with pli image in flash
    i have a 7025 if your wondering
  11. #26
    Nov 2008
    great..i like it thanks a lot
  12. #27
    keresely, coventry
    I have DM600C with an internal hard drive and I have the Pli image loaded in the flash. If I was being honest I would say the multiboot is a waste time for me because I have a play with the other images but I always come back to the Pli image as it has the 14 day EPG and the 'now and next ' on the infobar. On my Dm500 satellite box the mutliboot could be really handy as the images on the satellite side have a lot of plugins which are useful for different providers.
    curiours, how do you get 14 day epg on pli?? i cant even get half day epg
  13. #28
    Default hello friend
    does this feature works on a clone dm600 pvr?
  14. #29
    V.I.P. Member westkill's Avatar
    May 2008
    Quote Originally Posted by alwez View Post
    cant see why not
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
  15. #30
    Default 600C how to finish installation?
    Can anyone help me please.
    Got a 600C and can flash anything onto it no problem but of course can only see the FTA chans. Can any one give a newbie like me some tips or pointers to unlock decrypt all chans?
    Is it like a 500 where there's a additional soft to put on then Info button shortcuts?
    I'm lost with this - cheers all!
