Results 1 to 3 of 3
    Oct 2013
    Default Omega B, memory map, adress reference ++
    I am new to this issu, so some of my questions my be silly.
    I compete i motorsport i Norway, a type of stock car class, very low budget, and we mainly use stock parts, but so some mod on the engines.
    As for now i use Opel engines, what i work on now is a Omega B 1995 X20XEV engine with a Simtec 56.0(1) ECU
    My questions is?
    • This ECU has a 27c256 DIL memory chip, is it in this chip all the parameters that we want to change is stored in (Eg rev limiter, ignition timing, fuel map, immo)
    • Is there any overview of the contents of the file in memory, eg what adress is the rev limiter and so on.
    • The immo, is it possible to disable it, we use engines from one car in other models/brands, every thing inside the car i taken out, only the bare shell.
    Thank if someone can enlighten me.
    yes all taht can be done, but immo is in eeprom 93Cxx
    Oct 2013
    Ok, but how du i find out what adress rpm limiter is?
