Results 1 to 9 of 9
    Feb 2012
    Default Is there any way to flash firmware a DM 500 without a null modem cable?
    Old Git PaphosAL's Avatar
    Mar 2008
    Which image is on the dm500 at present, and which image are you wanting to flash?
    AL
    Feb 2012
    What it is a friend of mine bought a second-hand DM 500, but the part you plug the null modem cable into on the back, is not connected to the motherboard and can't be, it currently has a GP firmware but would like to put commando on their.
    Top Poster fazz69's Avatar
    Feb 2009
    Somewhere
    Quote Originally Posted by MW35 View Post
    well you should be able to thru your network internet. using your ethernet.
    check this video out
    http://www.youtube.com/watch?v=BovvFtD6Cis
    Feb 2012
    thanks mate i'll give that a try,
    Feb 2012
    Well I just followed that video exactly and everything went the same as the video, but now my box is bricked don't get nothing on the screen!
    Feb 2009
    Somewhere
    what image are you trying to install.
    Telnet Commands
    To flash an image using Telnet
    This method will only work with a .img image file.
    • Rename the image file to backup.img
    • FTP the image file to the /tmp folder on the dreambox
    • Telnet to your box and paste the following command:
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    To telnet, click START > RUN and type Telnet ip.address.of.dreambox
    A command window will appear, enter username root and password dreambox.
    To backup an image using Telnet
    • Telnet to the box and paste the following command:
    cat /dev/mtd/3 > /tmp/backup.img
    • FTP to the box and navigate to the /tmp
    • Here you will find the backup.img file.
    Feb 2012
    I done it exactly that followed the video to the letter said my box was flashed restarted my box but just get a black screen I was trying to update from GP to commando image.
    Aug 2008
    this is my favorite way
    h==p://dreamboxon.com/dm500-flashing-flashwizard.html
