Is there any way to flash firmware a DM 500 without a null modem cable?
Which image is on the dm500 at present, and which image are you wanting to flash?
AL![]()
What it is a friend of mine bought a second-hand DM 500, but the part you plug the null modem cable into on the back, is not connected to the motherboard and can't be, it currently has a GP firmware but would like to put commando on their.
well you should be able to thru your network internet. using your ethernet.
check this video out
http://www.youtube.com/watch?v=BovvFtD6Cis
thanks mate i'll give that a try,
Well I just followed that video exactly and everything went the same as the video, but now my box is bricked don't get nothing on the screen!
what image are you trying to install.
Telnet Commands
To flash an image using Telnet
This method will only work with a .img image file.
- Rename the image file to backup.img
- FTP the image file to the /tmp folder on the dreambox
- Telnet to your box and paste the following command:
cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
To telnet, click START > RUN and type Telnet ip.address.of.dreambox
A command window will appear, enter username root and password dreambox.
To backup an image using Telnet
- Telnet to the box and paste the following command:
cat /dev/mtd/3 > /tmp/backup.img
- FTP to the box and navigate to the /tmp
- Here you will find the backup.img file.
I done it exactly that followed the video to the letter said my box was flashed restarted my box but just get a black screen I was trying to update from GP to commando image.
