Does anyone have any solution for error c1414?
I already change the micro for a new one and the error continues.
Please someone who has the solution, I have 2 modules to repair.
I also work in electronics. Could you help me to repair it please? I do not realize that part of the plate was burned. Check all the components and do not find anything. If you could give me a help I would appreciate it.
Ola! Amigo! Eu tenho mesma problema com Peugeot 207 direção eléctrica não funciona. Queria saber se vose já resolveu problema da placa electrónica?
También tengo un problema. C1414 reemplazó los transistores de potencia 160N04, reemplazó 2 chips de controlador TLE7188F, el problema persiste, ¿qué cambiar para resolver este problema?
hi for error code p0606 someone have solution?
Meat-Head (15th September, 2021)
Use different scan tool as well
rafal (23rd September, 2021)
i clearind board from protective film end reweld all connection ecu work.
p0606 clered and don't coming back
Meat-Head (18th September, 2021)
Hello fra69,
Did you disassemble all boards into the module (communication / interconnection / power) or only the top board (communication) ?
I have also a failing power steering on my 207 with P0606 fault.
I would like to find the root cause and give the info to the community
It seems that this module has a hidden defect that has never been corrected by the manufacturer. I suspect that issue is coming from power board (under the interconnection board) because we can observe a burned area around the big inductor at the entrance of the +12V. I'll post picture later ...
Thank you for your reply.
I'll rework the communication board as you preconize.
I disassembled the other boards (translation board and power board). It's very difficult to disassemble them because they are soldered by spot welding.
Nothing seems wrong at this stage...
