Hi all,
Come back with good news.
I reworked the communication board by resoldering all components to be sure that I didn't miss something.
Reassembled all boards in the electric steering, and put it in the car.
I cleared the P0606 error code.
My electric steering is working like a charm since more than 1 month !
Like third party companies are able to repair the electric steering within 24 to 48h, I'm now pretty sure that they don't dissamble all boards. I suspect that every time, it's due to an electric problem on communication board that is pretty easy to remove... (board on top).
From my point of view, the problem is coming from a bad soldering process on the TLE7188F (3 phases bridge driver). I observed that solderings on pins were not correctly flowed with pin and crack was probably formed with time (heat, vibrations, ...).
After reworking, these solders were well hooked to pins.
I put pictures for comparison and also the potential root cause.
Good luck if you decide to rework this electric steering
Thanks again to Fra69 for his inputs.
And no thank you to Peugeot that has never seriously considered this problem and waited for customers to have a problem before changing one by one the EPS!
