Results 1 to 4 of 4
    saracevic's Avatar
    Netherlands
    Default sprinter 313 dpf help
    i have sprinter 313cdi 2006. problem with dpf. have allready changed dpf make adaptation with das. but dosn't work. after 10 min. limp mode. also changed dpf pressure sensor and made adaptation with das still no solution. now i have read flash and try do make dpf off with ECUsafe but still don't work. can somebody please look at this file and make dpf off thank you
    Yes is possible
    Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
    Sep 2012
    Hi i have sprinter 313cdi 2007. Problem ex- haust system got stolen (dpf ,temp sensor and oxygen sensor)
    ECU 0 281 016 864 sw 24.09 hw 25.08 r. Please HELP dpf off
