Hi all I am thinking of getting a vu+ duo 2. I have got a dreambox 800hd at the moment are they the same to setup or different and do I need any more wires to upgrade to a vu box with it been a twin tuner. Any advice will be great thanks
Hello
How manu wires Do you have at the moment, Just the 1? If so then the vu Will Still be ok with One but means you wont be able to record 1 channel while watching another, Also they are different to Setup mate
I have pm you mate
The only difference about the setup between the VU and the Dreambox is the flashing procedure, Vu are upgraded via USB Stick for image firmware where as the Dreambox are upgraded via Ethernet.
Everything else FTP/Telnet are identical including the folder structure layout
I have two wires coming from dish
then you can record and view anouther channel
or do what i do i have tuner B set on a static mini dish
and tuner A set on my motorised dish plus if i wish
i can record on the static dish and watch any chn or sat
from the motorised dish. and compared to dreambox the vu
wins hands down on every point, and my personnel view is
go for the solo2 it's a ?150 or so cheaper and just as good
but you dont get a very expensive lcd screen on a solo2 for
me that's more flashy than use to most users. the duo2 probably
has something that the solo2 does'nt but is it worth the extra cash
i cant fault the solo2 it's first class, but as always the choice is yours
Please Read Carefully!
No Sky UK NDS Videoguard Hacking Discussions.
Viewing Pay TV without a valid subscription is illegal
the files available are kept for experimental & educational purpose only
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
Monkeys, you would be pleasantly surprised with a VU Duo2 after using the DM800HD. The operation is similar to the 800 but is so much faster. A full reboot on my Duo2 takes about 20 seconds as opposed to my 800 which took about 5 minutes.
The major differences are; the image install is via a usb stick ( very easy indeed ); you need to configure the two tuners to suit your installation rather than just one.
All other operations are very similar to the 800 but in my opinion, very much better.
Sent from my crystal box, using my cat's whisker.
i agree mate the duo2 is bit pricey,and i standby
what i said about the solo2 at about ?150 cheaper
it's a first class box. and would like to know just what
apart from more tuners will it do that the solo2 wont
Hi benny,
It runs a more modern chipset than what the solo2 does although it still employs the same dual core 1300mhz processor.
The tuners are silicone based and not soldered to the board as in the Solo2 which means the Solo2 has to do a lot more on the CPU front to control and run software for the tuners
It has more ram and Flash space than the solo2 and as well as what you mentioned Pluggable tuners and the VFD display
is it worth another ?150 more probably not especially for just casual satellite viewing
