Results 1 to 7 of 7
    kazikk's Avatar
    Default Transporter T5 remove DTC
    Hi.
    Could some one delete faults codes from this file ?
    18325 - Relay for Coolant (J151)
    P1917 -000
    17848 - EGR Valve (N18)
    P1440 - 000
    19561 - Valve for intake manifold (N239)
    P3105 - 000
    18617 - Engine Coolant Temp Sensor (G38)
    P2185 -000
    We have use EDC16U1 038906016A - 0281010735 from Transporter T5 to ARL 150hp engine and need to remote this fault.
    Thanks in advance.
    FLASH-dtc-test.rar
    this is test.
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by chicco1 View Post
    FLASH-dtc-test.rar
    this is test.
    This doesn't look right
    Mar 2011
    Quote Originally Posted by kazikk View Post
    Hi.
    P1917 -000
    P1440 - 000
    P3105 - 000
    P2185 -000
    Thanks in advance.
    Use winols. Set the following to 000 (8 bit dec)
    0E89AE
    OE89C4
    0E89D1
    0E8A8D
    That should disable the four codes. If not, let me know.
  5. The Following 3 Users Say Thank You to Diagnosticated For This Useful Post:
    Hayssam1 (18th August, 2015), kazikk (4th November, 2013), wflseba (11th December, 2015)
    kazikk's Avatar
    Quote Originally Posted by Diagnosticated View Post
    0E89AE
    OE89C4
    0E89D1
    0E8A8D
    I thing that 0E8A8E should be 0 to eliminate 19561.
    Hi, you have solved?
    Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
    kazikk's Avatar
    Yes , Solved. - thanks to "Diagnosticated"
