Results 1 to 7 of 7
    kaToo's Avatar
    Default When engine HOT car won't start
    Can anyone help me with situation
    When engine is hot the car won't start
    I saw that there are some people who can fix hotstart problems
    Atached is the file fromg golf 4 1.8T with bosch ecu 0261206518
    If anyone can help me i will appruciate
    THANKS29F200 ORI.zip
    Mar 2011
    this must be something else wrong
    Nov 2011
    friend and friend
    only in diesel fuel can not think you can
    unplug your temp sensor when hot and try
    Nov 2013
    Texas, US
    My MB ML430 wouldn't start when hot due to crankshaft position sensor. No problem starting cold or if I drove then stopped and opened the hood it would start. To diagnose mine, when the truck wouldn't start, without turning the key off, read the codes--it would show a pending CPS code but if the key was turned off after failure to start no code would show.
    Spain
    Quote Originally Posted by kaToo View Post
    Hi M8,
    Your car doesn't start or hardly starts when hot?? because this are very different things, Petrol has his own tricks on hot engines startups!!
    Give us more details about.
    Regards.
    luis12's Avatar
    Jan 2011
    Panama
    Its very common failure of Crank sensor when engine is hot, a defective temperatura sensor can make this failure.
