Results 1 to 9 of 9
Thread: Help Remove DTC
    Oct 2011
    Default Help Remove DTC
    Hi mans. Somebody can help me to remove DTC p0602?
    Thanks in advanceWinOLS (VW Touareg (V0.rar
    Jun 2013
    EU
    hmmm guess that DTC cannot simply be "deleted" from the flash, seems your eeprom is empty or corrupted or ECU is defective.
    16986 P0602 Control Module Programming Error/Malfunction.
    Tell us the history of the car, and how it entered P0602. Did a flash process got interrupted?? Is the flash the original for this car ecu?... you know...
    Oct 2011
    the car run well... with ori file not lights.. with this file yes... and chk is ok.. i dont know why.. and car runs ok.. ao simply delete dtc i think
    Jun 2013
    EU
    Problem is P0602 i cannot see in the list, so ... it is hardcoded.
    Oct 2011
    so.. why i have this issue? chk is ok i think..
    fear_dark's Avatar
    Sep 2010
    send eeprom dump
    Oct 2011
    i didnt touch eprom.. and with ori is ok...
    Spain
    Hi M8
    Do you have Damos? Drivers? Settagio? Seems you made wrong modifications outside the maps or there are no coherence between that values you mod.
    Did you had problems with any map?
    Regards.
    Oct 2011
    the car runs ok so... and i think coherence between maps
