Results 1 to 15 of 15
    Mar 2011
    Default need isn from EWS4.3
    need isn from mini EWS 4.3
    thanks!!!
    vanos batam's Avatar
    Jul 2010
    Batam-Indonesia
    your isn
    bestregard
  3. The Following User Says Thank You to vanos batam For This Useful Post:
    dziongas (5th November, 2013)
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    ISN is: 341D
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  5. The Following User Says Thank You to lupu_sandu For This Useful Post:
  6. #4
    Mar 2011
    Do you know how could change ews4.3 to ews3? because my ews 4.3 defective, harnessing is immediately ruined eeprom file.
  7. #5
    south africa
    Default mini cooper ews 4.3
    hi can someone help me get the isn from this ews
    ews 4.3
    mask;2l86d
    flash mc9s12d64
  8. #6
    Jun 2014
    ankara-turkei
    501C ___WMWRF32070TN06845
  9. The Following User Says Thank You to caliskan71 For This Useful Post:
    trevormaharaj (13th March, 2017)
  10. #7
    south africa
    Default bmw x3 ews 4.3
    hi can someone please help me get the isn code
    ews 4.3
    2l86d
    flash mc912d64
    thanks in advance
  11. #8
    kiszka's Avatar
    Aug 2009
  12. The Following User Says Thank You to kiszka For This Useful Post:
  13. #9
    south africa
    hi there can you change isn code to 502F in ews can you lpease tell me what software used to retrieve isn code so i can buy sofwware thanks
  14. #10
    danyguit2000's Avatar
    Dec 2009
    Earth
    Changed to 502F
  15. #11
    kiszka's Avatar
    Aug 2009
  16. The Following User Says Thank You to kiszka For This Useful Post:
    trevormaharaj (14th March, 2017)
  17. #12
    south africa
    thanks alot guys work 100%
  18. #13
    south africa
    Default x3 ews4.3
    hi kizska tell me is it possible also to change the vin in this file if so can you please make it WBAPD92040WG01896 will apreciate it alot thank you
    i tried to do it with abrites and autologic diagnostics but its not writing the vin in
  19. #14
    kiszka's Avatar
    Aug 2009
  20. The Following User Says Thank You to kiszka For This Useful Post:
  21. #15
    south africa
    Default x3 ews4.3 flash
    hi do you have flash data file for this control unit
    zb ews4.3
    hw;06
    sw;v2 03 0006
