Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Oct 2011
    Hi. You are absolutely right but thats why we love it. There is always someone who has a different problem from someone else. By the way do you know anything about Spiderbox receivers, i have been offered a 9000HD new for 90 pounds. Are they as good as a 5402???
    Regards.
  2. #17
    happy_highlander's Avatar
    Aug 2010
    I haven't had much dealings with them at all m8 do wouldn't like to comment. I've only ever seen them being used, never used one myself
  3. #18
    digicon's Avatar
    Quote Originally Posted by Nutsandbolts View Post
    Regards.
    Ramjet is probably the best man to answer that as i believe he is a current user of one, My own findings with them are the 2 biggest bug bears is one they dont like Technomate Motor's in USALS mode and two they can have problems with a certain version of a popular Cam being used particularly beginning with the letter C
  4. The Following User Says Thank You to digicon For This Useful Post:
    happy_highlander (7th November, 2013)
  5. #19
    Aug 2010
    No different to the 5402 if the sender is over a specific version then
  6. #20
    digicon's Avatar
    Quote Originally Posted by happy_highlander View Post
    Never seen that problem HH on all the ones that i have seen anyway works straight through from 2.0.11 to 2.3.0, Tested it myself on my own 5402 never had an issue
  7. #21
    Aug 2010
    I never found out what version they were using digicon but it clears on vu no problems and although it registers as connected on tm it wouldn't clear. It was very weird but not something I spent to much time on. Only really went as far as a couple of fresh flashes at which point it cleared for a few minutes but that was it so I got fed up and filed it away under ballache for another day when I can be bothered
  8. #22
    chris0200
    Guest
    Just to update you all on my sync issues. n definitely works better than c, just need to sort out the picture freeze now. Been using homeplugs but just ordered a load of cat 6 to see if things improve.
    Thanks all
  9. The Following User Says Thank You to chris0200 For This Useful Post:
    happy_highlander (9th November, 2013)
  10. #23
    Aug 2010
    Cat 6 won't make a blind bit of difference. The ethernet port in the tm is only 10/100 so cat5 could carry it but cat5e would be more than enough. Homeplugs work perfectly and I'm beginning to think you have an issue with Internet if everybody you try is freezing. When was the last time you did a full system reboot. By that I mean box router modem the full works
  11. #24
    chris0200
    Guest
    The router was reset a couple of days ago as we occasionally have drop outs on our long line. I suspect we also have noisy mains as the laptop (connected via another home plug) has been lost connection a couple of times in the last few days. However, on turning the HPs off and on we then get the signal back and can remain stable for ages. If I am right then connecting direct to the router may help, what do you think?
    Thanks again.
  12. #25
    Aug 2010
    Yes definately. If connection to other devices is dropping off noticeably you don't stand a chance of receiving anything freeze free. Thing is does anything drop off when connected directly to router. If so then you have a bigger problem you need to address before you start messing with anything else on the box
  13. #26
    chris0200
    Guest
    Been working in my office today, as opposed to on the sofa, directly connected to the router and no drops yet. I have also been running Router Stats Lite software to monitor my connection over-time. Hopefully, my theory about the home plugs is correct, soon see the cable should arrive tomorrow.
    Thanks again
  14. #27
    Aug 2010
    I have 4 tp link av200 homeplugs serving a mixture of stb and smart tv with absolutely no issues compared to hard wired stb. I'm also aware of another member who has homeplugs from house to garage connected only by armored cable with no issues. These are also used to stream hd content from nas to smart tv and cope without issue.
  15. #28
    chris0200
    Guest
    Appears that the mains was causing the issues. Now have a cable training round the house and very few issues over the last couple of days. Now just need to route the cable up to the loft and down again.
    The only issue I now need to sort is getting the 7 day planner to work.
    Thanks for the help chaps
  16. The Following User Says Thank You to chris0200 For This Useful Post:
    mdt (14th November, 2013)
