Page 1 of 16 12345611 ... LastLast
Results 1 to 15 of 227
    lwood's Avatar
    city of angels
    Default SMOK BDM J-Tag original Thread.
    making this thread for us to talk about Original Smok BDM Jtag,.. NO CLONE.
    the purpose of this thread is to help each other out. because the tech support sucks donkey balls .
    DON'T JUST SAY PRESS IT.....
  2. The Following 7 Users Say Thank You to lwood For This Useful Post:
    euroscan1 (19th November, 2013), GameTheoryOptimal (28th June, 2018), gentian (28th March, 2024), henal (22nd April, 2020), keycar (29th January, 2018), lesfuller (25th October, 2017), yvespapou (20th June, 2015)
  3. #2
    lwood's Avatar
    city of angels
    ok. here is a tip. if your gettin different reads all the time with SPC560P50L3.
    make sure that all pins are clean, no pin should be dirty. make sure you remove all of the coating from chip and legs or pins.
    Quote Originally Posted by lwood View Post
    The professor discovered America......................... wooo hooooooo
    Plcautoparts's Avatar
    Mar 2013
    I have original smok programmer, new to it, trying to read a 2010 Toyota Camry renesas much solder all wires as shown on DOC but I'm not able to rear, I will post a picture tomorrow, maybe I will get better help here than smok support
    Sent from my iPad using Tapatalk
    A simple thanks would do, If it didn't work at least I tried.
  6. The Following 2 Users Say Thank You to Plcautoparts For This Useful Post:
    chahed (20th March, 2015), vavrich (18th May, 2018)
    lwood's Avatar
    city of angels
    Did you remove the resistor from the other side???
  8. #6
    lwood's Avatar
    city of angels
    anyone else having issues writing to SPC560P50L3 ???
    i could read and verify any part of the chip.. the problem i have is when i write. verify gets errors all the time. i have zero success writing to data flash.
  9. #7
    Mar 2013
    Yes I did. I did an upgrade on software and was able to read it. I'm posting data to verify I read correctly.
  10. #8
    lwood's Avatar
    city of angels
    Quote Originally Posted by Plcautoparts View Post
    i dont have the renesas unlucked
  11. #9
    lwood's Avatar
    city of angels
    i did the software update. thinking it was going to fix the writing issue i have with SPC560P50L3. no i still cant write to data flash.
  12. #10
    Jan 2011
    that picture is not the correct to read it in circuit..check documents,,, that write UART in circuit only...
  13. #11
    Jan 2011
    thats its a bad reading if you were able to read it like in the picture it was read wrong...
  14. #12
    Mar 2013
    Hello Amlgar, I connected as in DOC that came along the programmer, could you tell me what am I doing wrong please?if you have a picture of your set up will be nice.
  15. #13
    lwood's Avatar
    city of angels
    has anyone with j-tag successfully write to data flash SPC560P50L3????
  16. #14
    lwood's Avatar
    city of angels
    i made this for you. and anyone who needs it. made it for smok. it should work just fine.
    Rear Pinouts for smok
  17. The Following 21 Users Say Thank You to lwood For This Useful Post:
    br.balazs (22nd February, 2015), buga37 (17th October, 2014), chiorbeq (23rd February, 2014), cjohny (6th October, 2014), datapage (10th December, 2013), diag1001 (31st October, 2014), digikeys (6th December, 2015), Gary Diaz (13th September, 2019), hatimtai (20th February, 2015), jakesman (13th September, 2015), keycar (29th January, 2018), killlin (15th December, 2015), magdex (9th December, 2013), makz (23rd November, 2013), nicolaus (23rd November, 2013), pire cemil (21st September, 2016), SergeyIg (3rd February, 2023), taxo1965 (20th November, 2014), vavrich (18th May, 2018), wcysj08 (25th May, 2017)
  18. #15
    Mar 2013
    Pass please
