Results 1 to 5 of 5
    Nov 2013
    Default Dish not moving on skybox f3
    Hi guys, first of all i wanna let u know that i am a total newbie in this thing. Always relying on the technician doing all the setup/installation although i do understand some of the technical thing.
    So my problem first started when I want to flash a new channel list which resulting a boot loop after restart. After a successful flash through the null modem, i am left with a factory setting of the skybox f3.
    After flashing all the channel list i required, i soon found out that the dish does not move automatically like before. Even after entering the local longitude & latitude the dish still does not moved when switching between satellites.
    Any ideas to fix this? any tips is appreciated. Thanks
    BTW the skybox f3 is connected through a yuri diseqc 1.2
    P&D's Avatar
    Menu/sats'/switch on Usals for all sats
    Nov 2013
    Yeah tried that already. But still cant.
    Someone in the forum seems suggesting to realign with nearby sats and resetting the reference point at the motor.
    Will that help?
    P&D's Avatar
    if the dish has not been moved i'm sure you don't have to do that
    in the sats list are all the sats ticked on the left side
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    check the motor has power from the receiver, get on a ladder and use the manual buttons on the motor, this will rule out the possibility of either a faulty motor or a lack of power
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
