SIM2 backup uk OpenPLi-4.0-beta-dm800se #ssl84d + latest dmm drivers
  • southpaw
    • 2233
    THIS IMAGE IS FOR SIM2 DM800SE ONLY !
    I have tweaked the latest pli 4 on my sim2 800SE clone and finally got it running sweet, have created a backup for any who wish to try it, when I first flashed it I noticed a dramatic increase in pic quality and the box seems nice an zippy due to the latest dmm drivers finally being cracked by sim2 team, I have done the following to this image -
    removed -systemplugins fastscan+ osd3dsetup+ ppanel+ hdmicec+ module-rt2500usb-rt2800usb-rt73usb+ e2-helper+ sambaserver+ cablescan
    removed wireless support as i only use hard wired , you can re-activate if you download modules from server in plugins menu
    removed all language bar Inglish
    added cooltv
    added crossepg
    added xmltvimport
    added autobouquet
    added nfi flash tool to create this backup
    to install this image your box must be at ssl84a/b/c/d
    obviously put box in "stop" mode
    enter i-p from oled screen in web-browser address bar
    flash file sim2_800SE_SSL84D.nfi (do not boot box yet)
    after sim2_800SE_SSL84D.nfi file has flashed, in address bar re-enter the i-p address (or open a 2nd window and enter i-p again)
    flash 2nd file OE-exp-dm800se-2013-11-09-15-22.nfi
    boot box ,
    backup has dhcp enabled and autobouquet is set for "North West Granada HD" area. user can change to personal choice
    this backup will give a full epg if you configure your usb stick (which will automount on boot)
    to setup epg do- menu- setup- crossepg- configure
    configure crossepg to use your usb in "storage device"
    in xmltv providers tick "rytec uk xmltv" only
    save
    then go to plugins and select "epg import"
    click blue for sources and again select "rytec uk xmltv" only
    ok/green
    then to start the download/import hit yellow for manual
    let it do it`s stuff and hopefully that will give you a full epg for 5 days, (you can change the 5 to a 7 if you want in "load long description up to x days" (see screenshot above)
    think thats everythin, i have done a lot of experimenting and believe this is the best option for sim2 SE boxes available
    enjoy
    LINK - sim2_800SE_SSL84D.nfi https://www.dropbox.com/s/mpdwzx2hm0...0SE_SSL84D.nfi - OE-exp-dm800se-2013-11-09-15-22.nfi https://www.dropbox.com/s/vbarua5ld4...1-09-15-22.nfi
    to display picons on your oled screen , download file "skin_user.xml.zip" and unzip it
    download here
    when uncompressed, it should be a dotXML file type , ftp file "skin_user.xml" to directory /etc/enigma2/skin_user.xml
    download picons folder and unzip it, make a copy of it and rename the copy folder "picon_oled" (without quotes)
    you should now have 2 folders, "picon" and "picon_oled" , ftp them both to media/usb
    picons download here-
    reboot and you should now have picons displayed on box`s screen
  • freeiphone4
    • Nov 2013
    • 4
    thank you for this - i am new to all this and this made perfect sense.
    one question though - certain channels don't work - is that normal or have i missed something?
    EDIT: was not renaming CCCam.cfg after upload - sorted - thanks
    • southpaw
      • 2233
      Glad you sorted it yourself mate, well done, any feedback on performance welcome , personally think it's a massive performance step from 84b images with 2/3 year old drivers
      • stonewall
        • 42
        Hi mate
        Where does the picon file go and does this work on the OLED with this image?
        Thanks for your work!!
        • southpaw
          • 2233
          Picons go in a folder labelled picon on USB, to display them on oled you need a 2nd folder on USB labelled picon_oled and a slight modification to user skin file, I will upload that specific modded skin file on Sunday when I get home mate
          • digicon
            • 8261
            There is a Modification post for this here: http://www.digital-kaos.co.uk/forums...4/#post1583084
            • freeiphone4
              • Nov 2013
              • 4
              as i am new to this - your guide was the easiest for me to digest...it is working perfect.
              i am going to play with the picons etc as i am feeling more confident.
              Thank you again
              • stonewall
                • 42
                Southpaw
                Please could you advise? How does this image display ecm times, also struggling backing up the image? Apart from that excellent and your work is appreciated.
                stonewall
                • mdt
                  • 3034
                  Originally posted by stonewall
                  Southpaw
                  stonewall
                  why are you messing with back ups again? its your box and your choice i guess but you know what happened last time. regards mdt
                  DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
                  • southpaw
                    • 2233
                    Southpaw
                    stonewall
                    the 2nd info bar displays ecm times mate, just press ok-ok, the image has a plugin nfi image tools backup, this was the only consistent plugin that could create a backup that wasn't bloated , pretty straight forward to use, just tell it were to store backup and it will create a full nfi with your info within, good luck
                    • phat1
                      • 114
                      can this be in stalled in DM800HD, as when I try to flash it it says image for wrong architecture?
                      • southpaw
                        • 2233
                        nope, this image is for the 2nd edition dm800 , DM800SE
                        • rigsby71
                          • Mar 2009
                          • 676
                          This is an excellent image....very very fast and responsive to remote commands. Well done for a great image.
                          • southpaw
                            • 2233
                            Thanks for feedback rigsby, did you notice an improvement in pic quality or was that just placebo and my dodgy mince pies? just for clarity sake, I didn't create this image, its the excellent work of Mr GJStroom over at sim2 team HQ , I just tweaked the image to my liking, unbloated language packs and created a backup .
                            • stonewall
                              • 42
                              #15
                              Cheers mate!!
                              Thanks for the info! Yes I can see where the ecm times should be displayed but all I see is (0.000) .
