hi need help with dpf off sw1037396105 honda crv 2.2 i cdti read.zip
we have tested solution for this car with cruise control working.
the solution is not free
Ecu tuning, DPF, EGR, LAMBDA, ADBLUE and DTC, Remove
i hawe solution
yes this auto not free
there is one switch to disable all structure of DPF. Swiftec solution dont work. All people change many structure in file - its no need!
i made swiftec solution last update and car work good!
Yes swiftec solution is not good. On a good day might work for some km's. Eventually will give problems.
to do well this file not have to know what to do .. the only working solution is manual and there is much work to be done
When off right switch diagnosis generally ceases show a section with DPF!!!! counters regeneration and clogged filter do not work! and of course the cruise works perfectly!
