Page 125 of 135 FirstFirst ... 2575115120121122123124125126127128129130 ... LastLast
Results 1,861 to 1,875 of 2011
  1. #1861
    qwertyuiop12's Avatar
    May 2013
    Hi all, who knows how to program the buttons on Suzuki Jimny 2011,
    tried all the procedures that I found, but not one does not fit.
    I tried as Suzuki Swift, but not successfully,I try programming procedure with removal for 30 seconds negative (-) cable from battery but not work.
  2. #1862
    Aug 2014
    30 seconds from battery is the right procedure but your remote must be the one with the white plastic (very important)
  3. The Following User Says Thank You to Tyson500 For This Useful Post:
    qwertyuiop12 (27th June, 2019)
  4. #1863
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Can anyone tell
    Citroen c2 2006 flip key ,which version choose.
    Ori key was 2 button.
  5. #1864
    newone's Avatar
    Oct 2016
    Quote Originally Posted by drugowaz View Post
    Can anyone tell
    0536 NB Multifunction ASK
  6. The Following User Says Thank You to newone For This Useful Post:
    drugowaz (4th July, 2019)
  7. #1865
    Alekso's Avatar
    I see from X-horse have same remotes like Keydiy, is it the same remotes just a diferent names?
    Also whats woris me is that from Keydiy there is no big updates for a longer time, are they are OK?
    Did they plan to develop some programer on OBD
  8. #1866
    keyprogramming's Avatar
    They are not inter-programmable.
    As you say, very few updates coming through, I only check now every 2-3 weeks
    Quote Originally Posted by Alekso View Post
  9. #1867
    Feb 2014
    I can't find if anyone mentioned this but TRUNK button on remote 1K0959753G on Caddy 2007 doesn't work. Car accepts remote and lock/unlock buttons work but trunk button - no go.
    Original is working.
  10. #1868
    Jul 2015
    Hello, can my keydiy kd-x2 do remote for Hyundai Santafe 2008 Korean martket ( Vin is KMHSJ81VP8U369548) ? The original remote has 447mhz frequence. I used remote simulation function on keydiy kd-x2 for trying programming remote but not successfully. I tried a lot of Hyundai, Kia remote having 447mhz frequence.
  11. #1869
    Dec 2015
    Rafah, Palestine
    to generate a 447 mhz remotes you need a special B keydiy remotes like b2 and b10
    on the remote page there is instruction which remote type you need you cant simulate a 447 remote because it need a special crystal to that frequency
    Quote Originally Posted by trunggt2007 View Post
  12. #1870
    Jul 2019
    England
    Hi all, first post, been lurking a long time but could with some help and thought it was time to try and give back too. I need to program a keydiy remote to a 2010 transporter but the original is a 2 button, Ive tried to put a 3 button remote into one of these vans in the past but with no success, any help appreciated thanks
  13. #1871
    Apr 2016
    chinese version remotes is useless for kd mini device?
  14. #1872
    Hampshire
    I think there is a bug in the audi A3 style pcf type remote, tried to make a audi A8/touareg pcf type, from the pc software, it make the remote with success message, but when any botton is pressed the light stays on, when pressed again it goes out.
    ps. on Ds pcf style is ok.
  15. #1873
    sdnatlst's Avatar
    Aug 2011
    England
    isnt that normal? most audi remotes i have light stays on permanently if pressed,, until its programmed to the car.
    Tools owned -
  16. #1874
    Hampshire
    like i described above, DS pcf style is ok, when produced but when i produce the aud A3 pcf style, light stays on, i don't think this is normal, unless i am proved wrong and stand corrected. cheers.
  17. #1875
    Feb 2018
    Fabia 2001 2 button old style which KD remote to choose.
    Thanks.
