Page 130 of 135 FirstFirst ... 3080120125126127128129130131132133134135 LastLast
Results 1,936 to 1,950 of 2011
  1. #1936
    fred77's Avatar
    Jun 2019
    Berlingo M59
    Use to work tried on couple last few
  2. The Following User Says Thank You to fred77 For This Useful Post:
    p1et (11th June, 2020)
  3. #1937
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by Bazadgr8 View Post
    Morning Guys,
    I have a 63 plate I10 to do tomorrow and am hoping key diy will do, The remote is a HYR26 for those that use this ref or Genuine part number is 95430B4100. Has any one done one of these? it has a 46ex chip and wonder if KD will generate it as this or even xhorse.
    Look forward to your thoughts
    I think ...
    HA-T005
    But don't quote me
  4. #1938
    Quote Originally Posted by M3L3R View Post
    That remote working fine. I used it many times for sharan and alhambra. You have to do something wrong during manually programming.
    For Sharan is working standard learning precedure of generated remote or procedure is different?
  5. #1939
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by Boras View Post
    just lock (maybe unlock) door 3 times then push a button from memory,. same procedure
  6. #1940
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Please advice
    Citroen c4 picasso 2012. Which one?
    Upto 2010 i found info. Above 10 no.
  7. #1941
    Mar 2018
    hi 0523 ask multifunction ok.
  8. #1942
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Have you tested personaly?
    Because i upto 10 its 0536 ,doubt that 2012 its 23 and ask.
  9. #1943
    Mar 2018
    yes, some friends shared on face page. usually 0523 but some did 0536. headlight opening feature works.
  10. The Following User Says Thank You to musti418 For This Useful Post:
    drugowaz (20th July, 2020)
  11. #1944
    rob h's Avatar
    May 2011
    Any updates on this remote?
    Mitsubishi Space Star 2002-2005
    Remote
    Quote Originally Posted by Weasel3 View Post
    Hi, Jimmykey
    Any chance to do 2button GQ43vt6t ? I see it fits several vehicles US/Japan. I would need 433 MHz.
    If so any chance for HU56 blades as well? Need it for a 2003 Mitsubishi Spacestar.
  12. #1945
    Netherlands
    Mitsubishi Galant year 2001
    Remote control orginal number MR587282
    FCC ID G8D-520M-A
    which remote control can I use???
  13. #1946
    newone's Avatar
    Oct 2016
    Hello,it there any compatible for Toyota chr 89070-F4131 ?
  14. #1947
    Polotsk
    Hi Everybody! Who can help with pinout of plug on board inside remote key or may be anybody have schematic diagram adapter between PC USB port and PCB remote?
  15. #1948
    Alekso's Avatar
    What remote is for Toyota Corolla EU market from 2019-2020?
  16. #1949
    drugowaz's Avatar
    Mar 2015
    Lithuania
  17. #1950
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Hello
    has anyone programming the NB11-2 for FIAT G.P.? is need precode like the id46 chips? (I'm new to keydiy ..... do not laugh ....)
