Page 131 of 135 FirstFirst ... 3181121126127128129130131132133134135 LastLast
Results 1,951 to 1,965 of 2011
  1. #1951
    newone's Avatar
    Oct 2016
    Quote Originally Posted by Panathaole View Post
    Hello
    has anyone programming the NB11-2 for FIAT G.P.? is need precode like the id46 chips? (I'm new to keydiy ..... do not laugh ....)
    yes,always need precoding
  2. The Following User Says Thank You to newone For This Useful Post:
    Panathaole (25th January, 2021)
  3. #1952
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Hello
    if I program a remote type B and it does not work, I can not reprogram it elsewhere;
    is it useless anymore?
  4. #1953
    newone's Avatar
    Oct 2016
    Hello
    you can reuse b or nb as much times you want
  5. The Following User Says Thank You to newone For This Useful Post:
    Panathaole (12th February, 2021)
  6. #1954
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Yes, that I knew and i, but i try to reprogramming a B remote and its not possible..... I get remote programming successful, but i have no signal when i press any button, if it is connected by the wire i have signal, but if i disconnect it no signal....
    The remote is new, from the box..... Weird.....
  7. #1955
    newone's Avatar
    Oct 2016
    maybe bad remote,never had a situation like this...
  8. #1956
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I try two more keys(thats in box of keydiy), to make a remote of different types that uses b remotes, same thing, remote programming successful, i test frequency when is connected with wire and works.....
    If i disconnect it and use battery the led blinking when i push buttons, but no frequency out.....
    I don't understand.... The battery is new....
  9. #1957
    Feb 2014
    Sounds like a battery problem - did you open another new battery or another brand of battery?
    When you generate a brand new B remote for the first time does it work on the frequency meter with battery?
    Did you try on different frequency meter tool?
  10. The Following User Says Thank You to autoTkey For This Useful Post:
    Panathaole (4th March, 2021)
  11. #1958
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    hi again....
    yesterday i was trying to clone a key from vw t5 id48 chip recognized correctly, i put keydiy antenna to ignition for sniffing, turn on-off several times the key but keydiy didn't get any data.....
    why is that happens? do i need keydiy sniffer for this job?
    Thanks....
  12. #1959
    Feb 2014
    Not necessary to use KD Sniffer. It seems you didn't make the car to reset the immo - wait more before the next key cycle and take the key out every time. If still not OK increase waiting time more.
  13. The Following User Says Thank You to autoTkey For This Useful Post:
    Col19 (23rd June, 2021)
  14. #1960
    Hampshire
    Hi has anyone managed to program a kd remote for Hyundai I20, 2016, id 47 ?the part number is 95430-C7600 4F22? created this remote, but it would not program in, but the original one does, any ideas? i havent tried the xhorse one yet, thanks.
  15. #1961
    kostas's Avatar
    Jan 2009
    macedonia is greek
    Quote Originally Posted by nazz2 View Post
    try i20 elite india
  16. The Following User Says Thank You to kostas For This Useful Post:
    nazz2 (27th February, 2021)
  17. #1962
    Hampshire
    Have you tried this yourself? i am using a separate chip and remote haven't tried the multi function remote yer.
  18. #1963
    kostas's Avatar
    Jan 2009
    macedonia is greek
    Yes program the remote and transponder pcf7938
  19. #1964
    Hampshire
    Thanks will post result when customers come back net week.
  20. #1965
    Jun 2013
    KD - Team.
    The inventor of the universal remote. The rest is only copiers .
    I have a request, of a wish.
    I want to put a full size - Glass transponder.
    Like TPX2 - Silca GTI glass - or ID60 and ID63.
    With strong signal, in a key shell.
    Which also have a remote.
    With the options of 2 and 3 button. Or for the US market, maybe they also like the red alarm button.
    As far as I know. There is no option like this at the moment.
    So please develop a new shell, which have this option.
    Preferable is a flip key.
    But that is not so important.
    If its like Toyota style, (non flip). With exchangeable blades, using "roller pin".
    That is good enough.
    Most important thing:
    Good enough space to place a full size glass transponder. And remote at the same time.
    I know it can be done with the Audi B style. Then also need to modify the PCB.
    But it does not fit very vell.
    And can crack the glass transponder over time. And destroy it. So it will not start the car.
