2004 -2009 3 button C4, 3rd button for headlights?
ninja
ninja
DK- The Bogs Dollocks!!!
NEVER SAY IT CANT BE DONE!!
The thanks button works wonders!!
DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
any news on how to use on a 2005 renault clio, 1 button remote? Says need to use '46' mode key, can i use normal NB02 remote? if so, how to modify this?
I just updated my KD900 and now I see all the renault have gone and lots of others have disappeared too
Will these be making a return or gone for good?
I tried to program a 2003 mitsubishi outlander with a OUCG8D525M remote and it did not work, has anybody tried to make one?
I used b01 and b03 and none of them worked
another question is If I delete one brand can I get it back? How?
obdsystems (15th May, 2015)
me too i have this problem with kia ceed 0682 i try make but .............
i waitt to fix this problem
Works well on Peugeot 207 (2007 & 2008) although not listed
On the subject of NB-02 remotes, I'd check any you have for a sticking lock button.
Programmed one today for a Pug 207, clipped it all together for a final check.
Felt the click when I pressed the lock button, but no click on releasing it.
Looked at the LED and it was flickering.
Removed the circuitboard, checked and all buttons working OK, so put into another case, same problem.
Thought it was maybe due to the sealant over the aerial, so cleaned up as best as possible, still sticking.
Transferred circuitboard to third and last case, works fine.
On checking the faulty ones I noticed that looking inside the case, when you press the lock button, the rubber plunger that makes contact with the remote buttons, was not retracting and staying down, which was causing the problem.
Not had chance to see if its an easy fix yet, but if not, they'll be returned.
No point in giving them a squirt of WD40, and it dries up in a few weeks time.
Yes, with NB-02
Worked as 2 button and 3 button.
Need to program as 307 ASK
