Page 51 of 135 FirstFirst ... 41464748495051525354555661101 ... LastLast
Results 751 to 765 of 2011
  1. #751
    Quote Originally Posted by keyprogramming View Post
    For what its worth, back in September posting #500 I tried a few until I found the right one for a 2009 Peugeot 207CC.
    I used the same remote changing the firmware each time, but used the original flip remote as the first key each time.
    I programmed it with an AD100Pro which erases any existing keys, but don't know how this differs from other programmers.
    yes that could be the key thing... because maybe the car recognises the first key in the ignition so instead of erasing and programming with the data from the key, it uses the data it already has.
    and on the second key it has already deleted the data so gets it from the key.
    unless keydiy are wrong and it does not matter?
  2. The Following User Says Thank You to paul_12345 For This Useful Post:
    mikajna (25th January, 2016)
  3. #752
    gokey's Avatar
    try make key
    but appear this
    some idea ?
    PUSH reputation and thanks If you think I helped .............................
  4. #753
    foxtec800's Avatar
    I usually see that if the cable isn`t plugged in properly to my kd300, needs to be fully in.
  5. #754
    Dec 2013
    Quote Originally Posted by gokey View Post
    try make key
    but appear this
    some idea ?
    MOSTLY IS THE CALBE CONNECT ISSURE
    TRY TO CHANGE A CABLE TO REMOTES.
    AND ALSO SOMETIMES IF THE BATTERY TOO LOW
    ALSO COME THIS'
    WE ARE TRYING TO CHANGE THE TIPS
  6. The Following 3 Users Say Thank You to jimmykey For This Useful Post:
    Atex31 (27th January, 2016), gokey (27th January, 2016), PremierD (27th January, 2016)
  7. #755
    Feb 2014
    So this URG200 tool will work like KD900(support all remotes) but you will be able to buy it from anywhere, not only from dealers?
    And all other tools(KD200, KD300) will be stopped from production? Can anyone confirm that?
  8. #756
    Hampshire
    has anyone done denso Rav4 2xbotton remote?
  9. #757
    Feb 2014
    Quote Originally Posted by nazz2 View Post
    Ive used it on the toyota Previa and its worked
  10. The Following User Says Thank You to doolittle For This Useful Post:
    nazz2 (28th January, 2016)
  11. #758
    keyprogramming's Avatar
    Programmed a new NB11 (PSA Style) into a 2005 Citroen C2, original 2B flip(dead, so effectively a no keys job)
    Tried 206/207/C2 on the off chance it might work.
    Engine started, but no RCL which would make sense as this is for earlier fixed blade C2.
    Removed battery, reprogrammed same board as 2B ASK 0536, fitted battery, reprogrammed it, and it worked a treat, well impressed.
    Customer well impressed with new style PSA remote, even through it didn't have a badge.
    Forgot to mention, the circuitboard on these new PSA as so much easier to take in and out, compared to previous models
  12. The Following 3 Users Say Thank You to keyprogramming For This Useful Post:
    autochei (1st February, 2016), nedved59 (10th February, 2016), Weasel3 (2nd February, 2016)
  13. #759
    DottoreBL's Avatar
    Bosnia
    Where to buy that new PSA remotes ?
    4f 54 54 4f 52 45 20 45 4c 45 43 54 52 4f 4e 49
  14. #760
    Quote Originally Posted by DottoreBL View Post
    http://www.tradelocks.co.uk/keydiy-r...p-remotes.html
  15. The Following User Says Thank You to keyprogramming For This Useful Post:
    DottoreBL (4th February, 2016)
  16. #761
    Anyone tried updating their KD900 yesterday or today.
    Tried a few times yesterday, and again this morning, same problem.
    Progress bar for updating Handheld Device goes up to 97%, stops for 15 seconds and then message appears "Internet is slow now, please try later"
    Never had a problem updating before.
  17. #762
    Atex31's Avatar
    Feb 2011
    UK
    Same problem,
    Running 150Mb download speed so it's definitely not my end
  18. The Following User Says Thank You to Atex31 For This Useful Post:
    keyprogramming (2nd February, 2016)
  19. #763
    Quote Originally Posted by Atex31 View Post
    Same problem,
    Thanks for confirming it's not just me that's affected.
  20. #764
    This has happened quite a few times for me, where it updates most then fails leaving it saying there is 1 that needs updating.
  21. #765
    garagetech's Avatar
    Oct 2008
    Default ********KD900 remote generator********
    Will the kd do audi a8 4e 2005 remotes?
