Problem with fiat module on seicento, ducato with immobox 93c56. every time i open a file the software crash.
program a key to vw golf mk4 after TM100 try to read chip it show fail , because it try as magic2 and this chip is magic 1 , but the vehicle start and work well .
cj
PremierD (12th February, 2015)
Anyone know where to buy NB series remotes for KD900 in UK?
Have emailed Trade locks a couple of times but no reply.
Thanx.
Just made with the nb02 pegout 207, and is working perfect
DottoreBL (16th February, 2015)
tradelocks have stock arriving this week in uk
dustin2014 (17th February, 2015), obdsystems (26th February, 2015)
i noticed that the Remotes will not take a TPX Glass Chip was going to do one the other day but found that without Drilling a hole in the Case there no way you can use a TPX Glass Chip in these Remotes , so they need to Look into this , Carbon Chips are easy,anyone had the same problem? How did you over come This?
have they fixed problems with new NB remotes?
Smart match a very good function, i have KD900 you can use the tool to make a test remote for the car with out using up Tokens Which will save you time and Money on any Job, you will find you Don't need to hold a big stock of Remotes,you can cover a lot but there
always be stuff you cant cover, www.3dgroupuk.co.uk is for gen Remotes and keys that i use ,uapTradelocks website well worth the Visit, You need to be a Locksmith to open up an Account , 3dgroupuk.co.uk have live Geek Advice, But you will need the Vin Number, and some form of Id to get pin Codes, and Keys Cut to Code From them, so Lisson to Martin from Rapidlocksmith on Auto Locksmith Stuff Martin is a Wealth of Info![]()
ive never had a problem adapting the case to fit a tpx chip , though i prefer to use cn carbon chips for these , though i rarely clone with them , its cheaper and as quick on most to code in via obd with correct carbon chip so no need for an expensive cloning chip.
i know tradelocks have stock of the new nb remotes this week , i know some peugeot models work fine from the few test units that were sent out , but as new i bet there are bugs on some till ironed out .
from what i can gather only a limited stock of these have been sent out to distributors due to china closing down for chinese new year , so i expect whats been sent will quickly sell out , realisticly if production and shipping to distributors doesnt start again until after chinese new year then i suspect it will be mid to end of march before we see restock and ample stocks available.
obdsystems (22nd February, 2015)
Hi Jimmykey,
Is it possible to produce up a circuit board that would fit the VW Passat 3C/B6 also called VW Magotan.
If we just buy the circuit board from KEYDIY, and maybe use the empty key shells that sell from China for about 15USD. It would be great.
Possible to adjust frequency and choose if it ID48 or ID46. I guess the circuit board would need to have ID46 chip on every one of them. And just enable/disable via software if is ID46 or ID48.
Could this be done? I guess total costs would be 25-30USD for a complete key then.
Normally the price is about 60USD. Which is the cost of the complete key with circuit board in China. But I think this key is more like OEM quality.
keydiy will not provide the magotan shell pcb in short time.
but it will release the magotan software to kd900 software next month.
keydiy will make the all keydiy remotes function to mobile phone (android and iphone)
so in MAY, keydiy can release the full function.
i bet you will like it.
http://youtu.be/huUsxQK_NtE
I got some of the new NB series remotes the other day.
All of them had to be modified before they would work correctly.
When the keys were assembled, the unlock and boot button worked perfectly but the lock button would either stay down or would be become "sticky".
I filed about 1mm of the top of the lock button to make them work correctly.
All parts came direct form supplier.
Surely they must of known this was an issue?
Are you saying that KD900 will program customers Iphone or Android. So it will work as a remote fob open/close car.
So the key made to customer can actually be a empty key shell with transponder in it? It is a cool solution!
I guess it would be a good feature as long as the customer has a operative phone. And don't loose it.
And it would be a solution for low cost Passat/Magaton keys.
