Guys.
Any idea how long it take to clone id48 with KD tool?
Xhorse Tool key is a shit and take over 1 hour.
Guys.
Has anyone got a good tip for removing pin from the emergency blade on ZB04-4 / ZB04-3 , ZB04-4 comes with kia7 but not Hyn14R or the other way round, i dont fancy drilling the other side, any neat ideas welcome.
Yes stupid design from Kd, I am thinking of using a micro easy tap or reversed drill bit will post results.
Finally managed to do it, you need to use a 1,5 mm drill bit to drill tru the hollow pin, then from the other side use a 2 mm drill bit and enlarge the hole up to the pin, then use a solid punch to knock the pin out.
Anyone tried opel omega 2000?
I see listed. Program with opcom or what?
Renault ECU tool / IO terminal / A.S.W
Has anyone tried Hyundai I30, 2015 smart remote(the D shape type), its not in the list of XH or KD, thanks
Hi is there solution for nb multifunction key to work on 307 2004 remote?
Yes, it works flawlessly on all 307 - old and new. Just need to find the correct data to download in the empty KD key. It depends on the car so you will have to try a few times until it works.
VDO (8th September, 2022)
I see this one has very good feedback.
But there's always this one exception that does not obey any of your efforts... If the car has a working remote you can integrate it in the Xhorse Smart Key BOX tool or just tell the client to install a cheap car alarm with central locking feature.
