Page 133 of 135 FirstFirst ... 3383123128129130131132133134135 LastLast
Results 1,981 to 1,995 of 2011
  1. #1981
    Keyblade's Avatar
    Aug 2019
    Croatia
    Quote Originally Posted by turismou View Post
    It does not seem to offer much more than KD-X2
    I will wait more info on this tool before purchase, looks like Xhorse
    Sent from my Commodore 64
  2. #1982
    auto techniek's Avatar
    Mar 2017
    Guys.
    Any idea how long it take to clone id48 with KD tool?
    Xhorse Tool key is a shit and take over 1 hour.
  3. #1983
    Jul 2015
    Quote Originally Posted by auto techniek View Post
    Guys.
    It took 80 minutes yesterday. It deducts the points at be beginning, so you can't cancel the calculation.
  4. #1984
    May 2020
    Quote Originally Posted by gokart View Post
    I think it returns if you cancel, keydiy usually takes around 15 to 30 mins for me.
  5. #1985
    Aug 2009
    Hampshire
    Has anyone got a good tip for removing pin from the emergency blade on ZB04-4 / ZB04-3 , ZB04-4 comes with kia7 but not Hyn14R or the other way round, i dont fancy drilling the other side, any neat ideas welcome.
  6. #1986
    Jun 2013
    Quote Originally Posted by nazz2 View Post
    Yes I agree, I also have this problem.
    Should be a better solution.
  7. #1987
    Aug 2009
    Hampshire
    Yes stupid design from Kd, I am thinking of using a micro easy tap or reversed drill bit will post results.
  8. #1988
    Aug 2009
    Hampshire
    Finally managed to do it, you need to use a 1,5 mm drill bit to drill tru the hollow pin, then from the other side use a 2 mm drill bit and enlarge the hole up to the pin, then use a solid punch to knock the pin out.
  9. #1989
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Anyone tried opel omega 2000?
    I see listed. Program with opcom or what?
    Renault ECU tool / IO terminal / A.S.W
  10. #1990
    Aug 2009
    Hampshire
    Has anyone tried Hyundai I30, 2015 smart remote(the D shape type), its not in the list of XH or KD, thanks
  11. #1991
    Nov 2009
    europe
    Hi is there solution for nb multifunction key to work on 307 2004 remote?
  12. #1992
    Feb 2014
    Yes, it works flawlessly on all 307 - old and new. Just need to find the correct data to download in the empty KD key. It depends on the car so you will have to try a few times until it works.
  13. The Following User Says Thank You to autoTkey For This Useful Post:
    VDO (8th September, 2022)
  14. #1993
    Jun 2013
    Quote Originally Posted by autoTkey View Post
    Old manual - struggle with this.
  15. The Following User Says Thank You to Weasel3 For This Useful Post:
  16. #1994
    Nov 2009
    europe
    I try I think more then 5-6 and I can't make it work,starting is OK but remote don't
  17. #1995
    Feb 2014
    I see this one has very good feedback.
    But there's always this one exception that does not obey any of your efforts... If the car has a working remote you can integrate it in the Xhorse Smart Key BOX tool or just tell the client to install a cheap car alarm with central locking feature.
