Page 120 of 135 FirstFirst ... 2070110115116117118119120121122123124125130 ... LastLast
Results 1,786 to 1,800 of 2011
  1. #1786
    Aug 2009
    Hampshire
    Has anyone done mini cooper 2005 remote? i made one on hyundai style B serries with the mobile fone app, with bar cade, it makes the remote, but it will not sync!(defo Manual procedure), any ideas?
  2. #1787
    Jul 2015
    I believe it uses BMW system not Rover with bar code.
  3. #1788
    Aug 2009
    Hampshire
    The original remote style is not diamond shape!(3rd type in the app) i even tried the diamond shape, but it didnt work.
  4. #1789
    Jul 2015
    How many buttons has the original key?
  5. #1790
    Aug 2009
    Hampshire
    it has 3 bottons, but not sending signal.its the only key with the car, so i cant open it up to check, probably battery or terminal dry joint.it would be handy if someone has done this sort of remote with kd.
  6. #1791
    Feb 2016
    Hi mate, I did a 2005 Mini on Saturday used the diamond shape option remote under bmw, manual procedure worked fine
  7. #1792
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Did diamond key for a Mini One and more Beemers. Ignition + 2 buttons methode was always successful
  8. #1793
    newone's Avatar
    Oct 2016
    Quote Originally Posted by nazz2 View Post
    the 3 button bmw remote on kd works ok,all 3 buttons,the only thing in that do not work is the windows open close from remote
  9. #1794
    Apr 2016
    uk
    Quote Originally Posted by PocketHero View Post
    What about Mini?
    It's same programming for remote?
    Sent from my MI MAX 3 using Tapatalk
  10. #1795
    Aug 2009
    Hampshire
    Thanks all, it must be problem with the car, i tried both mini pincode and ews from the app, but it didnt work, although the original remote does not sending any signal. will investigate further.
    yes comizelu the on/off procedure are same for both cars.
  11. #1796
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by comizelu View Post
    What about Mini?
    Yes, 200, 900, mini, X2 same programing, manual teaching the same too
  12. The Following 2 Users Say Thank You to PocketHero For This Useful Post:
    comizelu (12th February, 2019), kostat (16th February, 2019)
  13. #1797
    newone's Avatar
    Oct 2016
    Hello friends,i would like to ask what do you use to glue transponder on b remotes pcb when there is no place in casing to put transponder there.Thanks in advance.
  14. #1798
    Mar 2019
    Germany
    Hello, I am new in this forum.
    My question, does it work together with a Renault Twingo II Remote control with 2 buttons ? The car was build in 2009. Anyone who has tested it up to now ?
    Thank you
  15. #1799
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by newone View Post
    Either BluTack, that never dries, you can remove it later too, or superglue.
  16. The Following User Says Thank You to PocketHero For This Useful Post:
    newone (16th March, 2019)
  17. #1800
    keyprogramming's Avatar
    May 2010
    Silicon sealant can easily be removed
  18. The Following User Says Thank You to keyprogramming For This Useful Post:
    newone (18th March, 2019)
