Page 118 of 135 FirstFirst ... 1868108113114115116117118119120121122123128 ... LastLast
Results 1,756 to 1,770 of 2011
  1. #1756
    Oct 2015
    i had two customers where remotes stoped work but after start car work again. thats psa cars, one with att36 second is multifunction remote. what happened?
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  2. The Following User Says Thank You to rokibar For This Useful Post:
    alclot (14th December, 2018)
  3. #1757
    Jun 2013
    Quote Originally Posted by autoTkey View Post
    Corolla maybe. But AYGO is a no-go, except for V3.0.
    Quote Originally Posted by newone View Post
    i know,was the first to find about the V3.0 and post in thread
    Only V3.0 PCB not older like V2.0 or V2.2 ? Many of the PCB,s have no number at all. Is this problem solved with update now? Well I did not stock this V3.0 PCB. I hope it gets sorted very soon. Also need to get me some green paint.
    To paint over, all the KD text on the PCB
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    lalaina74 (13th December, 2018)
  5. #1758
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Quote Originally Posted by rokibar View Post
    Lost sync between remote and car. @ starting the engine resync was made, that's why IT works again. Has nothing to do with keydi, hapens often with factory remotes too, because its PSA...
  6. The Following User Says Thank You to PocketHero For This Useful Post:
    rokibar (13th December, 2018)
  7. #1759
    Oct 2015
    Quote Originally Posted by PocketHero View Post
    no no it is keydiy isues. when this happened led indicator stop also. after started car all normal. booths customer sayd me it is often in last times. must solve it, they don't want open car with mechanic key.
  8. #1760
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Ok, but can't understad why they do that. Maybe they aren't 3.0
  9. The Following User Says Thank You to PocketHero For This Useful Post:
    rokibar (14th December, 2018)
  10. #1761
    Oct 2015
    not good if we have problems as with other cheap remotes.still looking how to solve it.
  11. The Following User Says Thank You to rokibar For This Useful Post:
    alclot (19th December, 2018)
  12. #1762
    Sep 2016
    Guys kd remotes work on micra k13 2013+ and juke 2015+?
  13. #1763
    misamix's Avatar
    Sep 2016
    Serbia
    For Peugeot 406 2003. yr I tried PSA CIR51 Peugeot 406 2001-2004 but dont work, any idea?
  14. #1764
    Feb 2014
    You tried only this one?
    It's not so straight forward with this tool. If one doesn't work you must try the next with the same looks. Sometimes even the remote with different looks may be the correct one.
    But you can't know unless you try.
  15. #1765
    Oct 2018
    Northern Ireland
    2015 Ford Fiesta U.K.
    Anyone done one if so could you tell me the code please
    Thank you
  16. #1766
    Feb 2018
    Did you solve it?
  17. #1767
    Oct 2015
    [QUOTE=BeatsByMe;3451158]Did you solve it?[/QUOTE
    -----------------not yet--------------------------recode and reprograming no help
  18. #1768
    keyprogramming's Avatar
    May 2010
    2011 Seat Leon 433Mhz 3 button new style 7N5 837 202
    Anyone managed to create one of these?
    Regards
  19. #1769
    Sep 2016
    You can do just VW 5k0837202AD.
  20. The Following User Says Thank You to qeso705 For This Useful Post:
    keyprogramming (22nd December, 2018)
  21. #1770
    Jun 2013
    Default Pug Partner - C Berlingo - One button old 1998-2001 ID33 - SX9
    Anyone have a part number for this PCB ?
    If KD Team came up with a solution for this remote, I would be happy.
    I have done some searches on the web. Can not find second hand, anywhere. Either new PCB.
    Thank you.
