Results 1 to 13 of 13
    Oct 2013
    Default skybox wont accept channel list
    hi folks. I need some help. yesterday while messing about(if it aint broke don't fix it ) I deleted all channels via the channel editor. I have since taken the box back to factory settings, re-inserted my c-line and done a complete satellite(hotbird and astra) channel scan. this has allowed me to watch channels through the large alphabetical list but the box still wont accept AJ`s channel list via usb upgrade or dump. I am now worried about losing channels the next time they move around. any help would be greatly appreciated!
    Oct 2013
    Central Scotland
    Remember that you have to "Delete" All Channels before you install a New Channel List.
    I have the F5s & Use The Lan Tool & send the Channel list From My PC to F5s.
    It takes a little longer, But it Works.
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by sealclubber View Post
    ...but the box still wont accept AJ`s channel list via usb upgrade or dump...
    What happens when you try to install the channel list?
    The file has to be named TP_PROG.dbs or the box wont recognise it.
    Jul 2008
    uk
    Oct 2013
    I tried the factory reset both with all settings deleted and with just pressing the blue button to leave the cline intact. when I update the channel list and press the info it says 1. TP_PROG.DBS(SAT,TP,PROG).....OK all other options are unselected. exact same by the upgrade or by thr dump by usb method. any other time I updated aj`s list it went without a problem. I get the feeling that messing around going into channel edit and deleting all channels I have deleted a setting that is preventing the channel list from upgrading, although that's just a newb guess
    Oct 2013
    thanks mate. previously when updating channel lists I never deleted all channels and never had a prob, only this time I did delete all channels in the channel edit menu and now it wont take the new list.
    May 2012
    You dont need to delete any channel. When you upgrade the TP_PROG.dbs it does exactly as it says and upgrades at the same time it removes the old list.
    The biggest mistake made when upgrading a channel list is pressing the yellow button before placing a tick next to the highlighted TP_PROG
    Hadron's Avatar
    Nov 2012
    E. London
    ...I get the feeling that messing around going into channel edit and deleting all channels I have deleted a setting that is preventing the channel list from upgrading, although that's just a newb guess
    I have installed hundreds of channel lists (well it seems like hundreds anyway!) after deleting the previous one without any problems.
    Deleting all the channels does just what it says & nothing more. Remember that you won't see your new channel list until you put the box into standby & then back on again.
  9. The Following User Says Thank You to Hadron For This Useful Post:
    sealclubber (24th November, 2013)
  10. #9
    Oct 2013
    thanks hadron. I`ve restarted the box after every upgrade attempt but still no aj faves. its as if I need to do the channel faves myself. I guess I`ll just need to put up with it.
  11. #10
    1 box i did i had to reboot it 4 times before the new channel list showed as it should... forst boot it was random characters,, 2nd boot some names were right and so on,, 4th boot all fine, but by then there was a new channel list out (joking )..
  12. #11
    May 2012
    Save any important info on the box and Factory Reset without making any selections.
    Menu
    Tools
    Factory Setting
    Yes
    Blue Button
    This will put all the favorite names that AJ's list contains.
    You will need to reset the time and dhcp
  13. #12
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    www.hddvbsw.com
    latest filmware just reflash it start new you might have done more than your letting on
  14. #13
    Jul 2013
    If it still aint working check that the usb stick is formatted to FAT and not NTFS.
