    Default Delphi DCM3.4 galletto write problem
    Hi! I can't write renesas ecu Delphi dcm3.4 using galletto3. Read ok. In galletto manual i see support DCm3.4 with Renesas 64F7058 processor, but ecu have R4F70590. I try to write like 7059 but without secsess. May be i must use different resistor for 7059, not 560Ohm? Or i must write 7059 like 7058? OR galetto don't support this type of processor? need some hint... Many thanks!
    mislav88's Avatar
    Mar 2011
    galletto v53 can r/w this ecu obd
    LaraVAG's Avatar
    Jun 2011
    In galletto there is other windows to read, other to write, check it,
    Piassini do it, if you have
    Sure? -i see only "Megane 1.5 e3/4 delphi DDCR". its not old ddcr, its dcm3.4 ecu. My G3 is Eu-clone with 2012 soft inc renesas r/w. Maybe you meant Peugeot DCM3.4, like 407 2.0HDI?
    yes, for "write" i select other menu.
    LaraVAG's Avatar
    Jun 2011
    In piassini you have left menu and must select sh7059
    Quote Originally Posted by LaraVAG View Post
    i don't have piasini
